timing jumped a tooth
Old Oct 9, 2003 | 03:29 AM
boonacka's Avatar
Default timing jumped a tooth
what would be symptoms of the timing belt jumping a tooth and throwing the cam timing off?
Old Oct 9, 2003 | 03:51 AM
JimBlake's Avatar
Default Re: timing jumped a tooth (boonacka)
When the cam jumped forward on my old '82 VW, it ran like crap. It was not subtle...
Old Oct 9, 2003 | 04:25 AM
boonacka's Avatar
Default Re: timing jumped a tooth (JimBlake)
did it idle like crap?
Old Oct 9, 2003 | 08:01 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">did it idle like crap?</TD></TR></TABLE>Actually it idled real nicely. Above about 2k rpm it really sucked. But I think that depends on which direction it skipped.
Old Oct 9, 2003 | 09:01 AM
boonacka's Avatar
well mine idles like crap.. sounds like a v8 with wild cams... but after 2500 rpm it runs smooth... so i really dont know whats going on.. i havent had time to lift the valve cover and check the cam gear timing marks.
Old Oct 9, 2003 | 09:17 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">... i havent had time to lift the valve cover and check the cam gear timing marks. </TD></TR></TABLE>Well, you gotta do just that. When I said it depended on which direction it skipped, that's exactly what I meant. It never happened to me, but I believe if the cam skipped back it would do what you're saying.
It's just pointless for me to guess from here until you check your cam timing. If it's OK then we can try to think of something else. You brought up cam timing in the first place, as if you have some reason to believe it's messed up?
Old Oct 9, 2003 | 10:40 AM
boonacka's Avatar
well i asked that because i dont think its ignition because all ignition components checked out. cam timing was the other logical thing that came to mind. i was just curious to see if anyone else experienced the same problems/symptoms as me.
i'll check the cam timing tonight and let you know. thanks
zensoku207
Mar 21, 2005 10:48 PM
crxgsr91
Oct 22, 2004 05:41 AM
bb6h22
Oct 11, 2004 10:28 PM
CRX+MaAN
Jul 21, 2004 03:24 PM
JdmIntegra98
Jun 9, 2004 06:23 PM
