http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33629&item=2435341421
Old Oct 9, 2003 | 01:12 AM
Loveless's Avatar
Default sdsds
http://cgi.ebay.com/ebaymotors...41421
I was about to buy a carsound catalyst convertor but I read this:
2.25" Carsound Universal High Flow Catalytic Converters
2.25" Inlet and Outlet Diameter
High Flow
Stainless Steel with Aluminized Heat Shield
Universal Replacement Converter
With or without the air tube (If not specified with air will be sent, if you are not sure what you need then get the converter with air as it includes a cap in case it is not needed at time of installation)
what is this air tube? I did a search and no one mentioned about an air tube on carsound. Which one should I get? I only have one o2 sensor, is that what it meant by air tube? a hole where the secondary o2 sensor goes in?
Old Oct 9, 2003 | 06:02 AM
WundedSaint's Avatar
Default Re: sdsds (Loveless)
air tube is for cars with smog pumps...
Old Oct 9, 2003 | 06:28 AM
b18c4door's Avatar
Default Re: sdsds (WundedSaint)
rotary's like the FD3S also used the air pump to help reduce lag - I may have read wrong!
I have bought carsound cats(2.5" and 3") from performancepeddler on ebay in the past. His service is quick and he is a nice, friendly seller. Look at the link below, first one...He sells the crap outta magnaflow/carsound on ebay
http://cgi6.ebay.com/ws/eBayIS...tab=0
Just ask for the cat without the air tube in whichever size you need. Hope this helps!
Old Oct 9, 2003 | 10:58 AM
Loveless's Avatar
Default Re: sdsds (b18c4door)
thanks apu, you were very helpful
Old Oct 9, 2003 | 11:35 AM
IntEGNYC's Avatar
I heard bad things happening with Carsound Cats. Something about the element breaking or falling apart after a while...
Just thought i'd letcha know before you bid. Might want to hear feedback from other guys here.
Old Oct 9, 2003 | 11:41 AM
P1mpSlap's Avatar
why?
I got some NOFX tickets or an SMS header in my sig I'm giving away.
I know you guys want those.
Old Oct 9, 2003 | 12:00 PM
samagon's Avatar
doesn't matter, just be sure if you get the one with the pipe on it, that you have it angled so the pipe doesn't stick to far down.
EGcivicBoy
Dec 13, 2003 09:17 AM
tegtip
May 22, 2003 09:20 AM
Gennady
Mar 26, 2002 12:24 PM
