blown head gasket??or is ti the head...
just swapped out a headgasket but its still leaking.....sent the head to get it cleaned and they didnt say anything so im guessing its in good condition...basically wat happened is a freind borrowed the car took it out..came back and the shifter was snapped and oil was leaking all around the head and engine overheated bad...so i thought it was a headgasket...swapped it out..and still leaking...what else could it be??..please anyone...help..gettin so frustrated im bout to juss take a slug to da whole damn car...oh yea its a 99si with a crv block and b16 head....oh yea usually on a blown head gasket is it very noticeable or do u really have to look hard for the damage area???
When you had the head cleaned, did you have them check the deck to make sure it did not warp? There is a possibility it may have warped near one of the water jackets, it is also possible the block could have warped and needs to be re-decked.
Upon the install of the new gasket, did you get new head studs? Unless you run arp's, honda recommends replacing your head studs with new ones everytime the head is removed due to bolt stretch.
What I would recommend first is killing your friend after he pays for everything to be fixed. That's really fucked up on his behalf. I had a very similar situation happen to me about 2 years ago. You have no clue how much self control I had to have when he came back with my car grinning from ear to ear and when he parked steam started pouring from my engine bay and my water temp gauge was maxed out while my avc-r read .8 bar (peak-hold value).
Sorry to get off topic, I really feel bad for you.
thanx for the reply....i did use new honda studs...did not get the head or block checked to see if tis warped or not....so best bet is to take everything back off and send it to a machine shop again???on the sotck studs its torqued to 61 right????...i was told 61 but please tell me im wrong and let that be the prob.....
Did you torque the studs in a 2 step sequence in a criss cross pattern? Did you coat the threads with engine oil or moly lube as well?
If you decide to move the head, double check the torque values before removing the head. You might discover the bolts backed out and just needed to be retorqued. I do not know the exact torque value for the b16a with b20 block, but I think the regular b16a requires 61ft-lbs.
On my H series this is how they recommend the torque sequence be followed, it could be different on your motor... I'm not 100% sure- check your manual:
intake: 9 5 1 3 7
exhaust: 8 4 2 6 10
Loosening sequence:
intake: 3 5 9 7 1
exhaust: 2 8 10 6 4
intake: 9 5 1 3 7
exhaust: 8 4 2 6 10
Loosening sequence:
intake: 3 5 9 7 1
exhaust: 2 8 10 6 4
rfactor
Apr 26, 2005 03:27 PM
I8ayellowcrayon
18
Jan 29, 2004 11:42 AM
