cracked head??..blown gasket??
just swapped out a headgasket but its still leaking.....sent the head to get it cleaned and they didnt say anything so im guessing its in good condition...basically wat happened is a freind borrowed the car took it out..came back and the shifter was snapped and oil was leaking all around the head and engine overheated bad...so i thought it was a headgasket...swapped it out..and still leaking...what else could it be??..please anyone...help..gettin so frustrated im bout to juss take a slug to da whole damn car...oh yea its a 99si with a crv block and b16 head....
what headgasket did you put in? check the block for warpage, and did you use new head bolts(which bolts did you use), and how did you torque them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_CHEESE! »</TD></TR><TR><TD CLASS="quote">is your block warped? or any kind of warping?</TD></TR></TABLE>
Torqued to spec?
Torqued to spec?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 »</TD></TR><TR><TD CLASS="quote">
Torqued to spec?</TD></TR></TABLE>
thats what i was wondering....... also were they torqued in the right pattern?
just got done taking it back apart.i did torque everything to spec in sequence.headgasket and block head everything all good..some how i manage to strip a couple of the holes on the block the first time.i sent it to the machine shop to get it fixed(200 bux) but it didnt workafter running the motor for about 10 minutes i guess it worked its way loose...its totally stripped again(this **** sux!!!!!!!!!!)gotta see if i could get my money back now form the machine shop...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiftee_su »</TD></TR><TR><TD CLASS="quote">I did torque everything to spec in sequence.headgasket and block head everything all good...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">some how i manage to strip a couple of the holes on the block the first time.</TD></TR></TABLE>
If that's not an oxymoron, I don't want to know what is!!!
BTW, shoot your friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybridize »</TD></TR><TR><TD CLASS="quote">
BTW, shoot your friend.</TD></TR></TABLE>
yeah i was wondering when someone was going to say something. i would have killed this so called friend, after he fixed my car of course.
LOL... your friend blew your motor and snapped ur shifter.. why was he beating on your car?.... what a bastard
. hope you find the problem good luck
michaellong
Jul 30, 2018 07:37 AM
ProjectDarkBlack
Jan 4, 2006 11:24 PM
