N/A Build Up ? please
Old Oct 8, 2003 | 06:49 PM
Accordhspec's Avatar
Default N/A Build Up ? please
I have a jdm h22 and was wondering what is the highest the motor could be bored out to. I have seen the one guy on here with 2.44 is that the max that the motor can be bored to? what is the cost for such a build up. I am looking to get close to 250 whp if possible or more safely and reliably. Any suggestions appreciated thanks. I really dont want to turbo either however I did consider SC but reliability and every day use is key
Old Oct 8, 2003 | 07:07 PM
str8rcn's Avatar
Default Re: N/A Build Up ? please (Accordhspec)
250 is setting a pretty high goal.Most of the fully built h22's are doing 215-230 whp.250 is possible but not good for daily driving due to the compression required to put down such numbers.89mm pistons are a popular choice i think someone on gere is running 90mm but thats pretty big.
As far as money goes thats going to be determined by how much you can do yourself.
Old Oct 8, 2003 | 07:23 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accordhspec &raquo;</TD></TR><TR><TD CLASS="quote">I have a jdm h22 and was wondering what is the highest the motor could be bored out to. I have seen the one guy on here with 2.44 is that the max that the motor can be bored to? what is the cost for such a build up. I am looking to get close to 250 whp if possible or more safely and reliably. Any suggestions appreciated thanks. I really dont want to turbo either however I did consider SC but reliability and every day use is key </TD></TR></TABLE>
An h22a cant get to 2.44L. That's 2point6, he has a 98mm welded crank to get that displacement. The H22a crank is 90.7mm and with an 89mm bore I am running 2258cc or so, same as the H23, 90mm would get you up to 2308, still 2.3
Old Oct 9, 2003 | 07:03 AM
19924ws's Avatar
The H23 has a 95 mm stroke which would have you closer but not even to 2.400
Old Oct 9, 2003 | 07:14 AM
Nick M's Avatar
Default Re: (19924ws)
https://honda-tech.com/zerothread?id=180883
good place to start
Old Oct 9, 2003 | 07:57 AM
SweepeR 7's Avatar
Default Re: (Nick M)
hey, what would a prelude with 215 whp N/A run 1/4? do u konw how much the 0-60 would improve?
Old Oct 9, 2003 | 08:02 AM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accordhspec &raquo;</TD></TR><TR><TD CLASS="quote">I have a jdm h22 and was wondering what is the highest the motor could be bored out to. I have seen the one guy on here with 2.44 is that the max that the motor can be bored to? what is the cost for such a build up. I am looking to get close to 250 whp if possible or more safely and reliably. Any suggestions appreciated thanks. I really dont want to turbo either however I did consider SC but reliability and every day use is key </TD></TR></TABLE> If you are looking for reliability but want a "stroker" engine, then I suggest duplicating my engine set-up. IF you are not totally interested in reliability (long engine life) then you can go even bigger than the 2.44ltr that I have by boring out the cylinders a bit more, but this will have tradeoffs.
Old Oct 9, 2003 | 09:15 AM
solowerks's Avatar
according to my shop manual, it says you can only bore a h22a1 to .25mm or 0.010".. Same goes for h23a
Old Oct 9, 2003 | 09:37 AM
2point6's Avatar
Default Re: N/A Build Up ? please (solowerks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solowerks &raquo;</TD></TR><TR><TD CLASS="quote">according to my shop manual, it says you can only bore a h22a1 to .25mm or 0.010".. Same goes for h23a</TD></TR></TABLE> That is correct... using factory sleeves and pistons.
truplayaz24
Oct 13, 2007 03:16 PM
2.2lude88
Jun 22, 2007 05:03 PM
dk4ever
Jun 6, 2007 05:27 PM
95accordh22a
Mar 17, 2005 03:30 PM
coldfiremx
23
Nov 22, 2003 11:22 PM
