which BFG's should i buy?
Old Oct 8, 2003 | 06:44 PM
KoRE's Avatar
Default which BFG's should i buy?
Hi, just as the title says... i'm looking for which will give me the best grip...
the 225/40/14, or the 205/60/14
i know the 225 is wider and more contact patch but the 205 has the bigger sidewall and don't the bfg's have a soft wall(crinkle) which would also be an advantage?
help me out its for an EF hatch ls/vtec all motor going for 12's on slicks but would like to do em on drag radials also...
any help would be great thanks
Old Oct 9, 2003 | 04:57 AM
advanracing62's Avatar
Default Re: which BFG's should i buy? (KoRE)
so you're looking for a drag recommendation? If you're using DOT tyres I would think the footprint between the 205and 225 would be a sligh bit negligable for you. I'm not a drag racer so all I can comment on is footprint which is roughly .35" wider, if I remember right. Seems you are more concerned about the sidewalls here so I'd go with a larger sidewall profile over the actual size of the footprint. HTH
Old Oct 9, 2003 | 05:20 AM
AussieK24's Avatar
Default Re: which BFG's should i buy? (advanracing62)
Agreed, sidewall is much more important than width IMHO
Old Oct 9, 2003 | 06:02 AM
KoRE's Avatar
Default Re: which BFG's should i buy? (AussieB20vtec)
so you guys think the 205's would be better?
Old Oct 9, 2003 | 06:21 AM
according to you the 205 have a bigger side wall... so then yes
Old Oct 9, 2003 | 10:39 AM
King Tut33's Avatar
They aren't wrinkle walls, they are just drag radials. I don't think the sidewall will matter much. If you can fit the 225s, I would go with those. I have the BFG g-Force 205s, and I can take a pic of them if you want to see the sidewall.
Old Oct 9, 2003 | 11:55 AM
KoRE's Avatar
Default Re: which BFG's should i buy? (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">They aren't wrinkle walls, they are just drag radials. I don't think the sidewall will matter much. If you can fit the 225s, I would go with those. I have the BFG g-Force 205s, and I can take a pic of them if you want to see the sidewall.</TD></TR></TABLE>
pic would be nice... i was informed that the sidwall does crinkle not completely like a slick but like it...
thanks for the pic
Old Oct 10, 2003 | 07:06 AM
T4eg's Avatar
the 225/40/14's side wall is 40% of the width of the tire (225)
205/60/14's side wall is 60% of the width of the tire (205)
Old Oct 10, 2003 | 12:07 PM
King Tut33's Avatar
Yeah, I will see if I still have pics of them on my comp when I get home, or I can take some new pics.
Old Oct 10, 2003 | 11:16 PM
KoRE's Avatar
it's ok if you can't find them i decided on the 205/60/14's thanks
what 60 foots you think i can pull with those and skunk 2 drag launch springs
93bubble87
Sep 14, 2010 11:35 AM
95ejjj
Jun 9, 2005 05:58 AM
akio74
Nov 13, 2004 01:57 PM
LsTurbo91
Jan 19, 2002 03:39 PM
