no oil pressure! oil light on!
Old Oct 8, 2003 | 05:42 PM
Cashflo's Avatar
Default no oil pressure! oil light on!
My oil light is still on. I just replaced my gsr oil pump with a type-r one. I cleaned my oil pickup and my oil pan is free of dents. There is no v-tec so its obvious its the oil pressure. Im not losing oil either, the oil level is fine. If my vtec isnt hitting wouldnt I throw a cel code 22? Im just wandering what else in the engine has to do with oil pressure? Any help is appreciated.
Old Oct 8, 2003 | 08:02 PM
snowseeker's Avatar
Default Re: no oil pressure! oil light on! (eghead)
Did you change your oil pressure sending unit?
Old Oct 9, 2003 | 01:17 AM
Cashflo's Avatar
Default Re: no oil pressure! oil light on! (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Did you change your oil pressure sending unit?</TD></TR></TABLE>
no
Old Oct 9, 2003 | 06:28 AM
advanracing62's Avatar
GSR and ITR are the same pump, but ok... did you replace all the gaskets as well? replace the o ring? I know you didn't replace the sending unit... more info please
Old Oct 9, 2003 | 06:33 AM
snowseeker's Avatar
Default Re: no oil pressure! oil light on! (advanracing62)
Why are my post's getting screwed up here? I posted did you change your sending unit. Than after that I had, because if the light is on vtec will not work.
WTH? Who is editing my posts for me?
Old Oct 9, 2003 | 01:35 PM
Cashflo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Why are my post's getting screwed up here? I posted did you change your sending unit. Than after that I had, because if the light is on vtec will not work.
WTH? Who is editing my posts for me? </TD></TR></TABLE>
Well if I take of the connection then the oil light will turn off, so should my vtec work now? I thought the oil pressure sending unit was a connection of its own, not related to the ecu.
Old Oct 9, 2003 | 06:12 PM
Wesyder's Avatar
its separate.... did you prime the pump before installation if so then put a temporary manual oil pressure guage to verify oil pressure if you have pressure then sender is bad
Old Oct 10, 2003 | 08:26 AM
snowseeker's Avatar
Default Re: (Wesyder)
I thought for sure that the ecu used that same sending unit as the light? Hmmm. Learn something new every day.
Old Oct 10, 2003 | 09:39 AM
spaceman's Avatar
Default Re: (snowseeker)
whats the sending unit?.do you need to replace the oil pick up unit or is that the same thing?
Old Oct 12, 2003 | 07:29 PM
fox297's Avatar
Default Re: (spaceman)
I think your oil sensor might have been shot. I was driving one day and my oil light turned on, I was so scared, but it turns out that the oil sensor went bad. I didn't even bother to replace it since I had a separate oil gauge.
Old Oct 25, 2003 | 01:04 AM
Cashflo's Avatar
Default Re: (fox297)
ok im frustrated, does anyone in socal know what shop I can go to, to get this sh@# diagnosed. Im fed up and cant figure out why my damn oil pressure is low
Old Nov 21, 2003 | 04:35 PM
MrEg's Avatar
i got some friends at a shop in la mirada and a few others in westminster....LMK
Old Nov 21, 2003 | 05:02 PM
Cashflo's Avatar
Default Re: (mr_timluu)
fixed
Old Sep 4, 2006 | 04:27 PM
ThrustVin's Avatar
Default Re: (AIM:eg6bronze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AIM:eg6bronze &raquo;</TD></TR><TR><TD CLASS="quote">fixed</TD></TR></TABLE>
how?
Old Sep 4, 2006 | 08:47 PM
90b20vteckidd's Avatar
Default Re: no oil pressure! oil light on! (AIM:eg6bronze)
HOW?
Old Sep 5, 2006 | 02:22 PM
potatostix's Avatar
I'm guessing it was the oil pickup he talked about cleaning....
TORTUGA
Oct 28, 2013 11:32 AM
lonewsome
Jan 1, 2009 01:42 PM
mtownek9
Apr 1, 2008 01:54 PM
toyH22
May 31, 2006 02:05 PM
Cashflo
Apr 17, 2003 03:20 PM
