At 2500RPM
Old Oct 8, 2003 | 04:03 PM
tnkw's Avatar
Default At 2500RPM
well, is it just me or that any other ITR out there can shift back to neutral at 2500RPM without steping on the clutch?
will it harm my transmission if i do that often?
If this is not something that is ment to do wuz wrong with it...
I am talking about if i step on the gas and match to rpm to 2500 then i can shift from any gear back to neutral without steping on the clutch... interesting....
Old Oct 8, 2003 | 04:07 PM
reverie's Avatar
Default Re: At 2500RPM (tnkw)
It can't be good, I can tell you that much.
Old Oct 8, 2003 | 04:25 PM
97SpecR's Avatar
Default Re: At 2500RPM (reverie)
Does it do it just after you let off the gas? If so that is normal.
Old Oct 8, 2003 | 05:29 PM
MiraiZ's Avatar
Default Re: At 2500RPM (97SpecR)
I don't think its too bad...you can technially shift gears without hitting the clutch if you rev match
Old Oct 8, 2003 | 06:05 PM
tnkw's Avatar
yeah
at 2500rpm right when i let go of the gas
i can shift the gear back to neutral smoothly
so u guys think its normal and whon't harm the car????
Old Oct 8, 2003 | 06:09 PM
Haunt's Avatar
Default Re: (tnkw)
It won't hurt the car unless you start jamming gears together...
Edit: I agree that it will create more wear, but it won't create a ton of wear at all...
Personally...I use the clutch...less things to break...
Modified by Haunt at 11:22 PM 10/8/2003
Old Oct 8, 2003 | 06:17 PM
tnkw's Avatar
oooo
icic
but why can you shift a gear into neutral w/out stepping on the clutch at certain rpm???????? sorry for this noob question
Old Oct 8, 2003 | 06:32 PM
vtec.dc2's Avatar
yes.. that creates more wear.. so use clutch pedal everytime you shift
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnkw &raquo;</TD></TR><TR><TD CLASS="quote">
will it harm my transmission if i do that often? </TD></TR></TABLE>
Old Oct 8, 2003 | 06:41 PM
97SpecR's Avatar
Default Re: At 2500RPM (vtec.dc2)
Im a Honda Tech, we get the same question out of alot of people. They will be driving along with their hand on the shifter and they let off the gas and it "pops" out of gear. it really does not hurt or wear anything out. I do not recommend going out and doing it everytime, but just try not to do it.
Old Oct 8, 2003 | 10:06 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
It's fine.
I do this a lot. I can also go from 5-4, 4-3 without using the clutch, and you'd never know by riding in the car. 3-2 is a little harder.
If it feels smooth, don't worry. If you're forcefully popping it out, worry.
Old Oct 9, 2003 | 01:23 AM
tnkw's Avatar
oookie
thanks a lot guys~~ ^^
i've learned something today
Ef4doorwagon
Nov 28, 2014 10:17 PM
ateeb786
Nov 6, 2006 07:15 PM
soon2bdropped
Jun 15, 2005 09:56 PM
B-Hatchie
Oct 2, 2004 12:52 PM
95vtec
Aug 15, 2001 08:07 PM
