Engine vibration @ 2500-3000rpms, help!
car: '95 GS-R with 84k miles
when i accelerate at half or full throttle, the car shakes at around 2500 rpm, in 2nd and 3rd (at lower speeds). i can feel the shuddering through the gas pedal, steering wheel, and even the windows rattle.
any clues? the car is pretty well-maintained - it has a new fuel filter, air filter, valves were just adjusted, injectors were cleaned, and new plugs. the only other thing i know is wrong is a leaky cam seal.
would a bad 02 sensor have any affect? or maybe a new cap and rotor would help?
thx in advance
rich
thx in advance
rich
This is just a suggestion, Im that that brilliant but maybe check your motor mounts??? Maybe they wore out or ripped. If they arent that bad I think you can get away wih throwin the Energry Suspension Bushings in there and get a little better peformance while youe at it. Ive also heard these vibrate a little. I have yet to be lucky enough to put mine in yet. Good luck tho.
i just had the axles replaced, and i already have ES motor mount inserts
it's directly related to accelerating...dang i'm stumped
prodragEG
Oct 30, 2007 05:12 AM
