aem cold air help
Old Oct 8, 2003 | 02:22 PM
xALL MOTORx's Avatar
Default aem cold air help
ok guys i just got an aem cold air intake and when i went to put it on i noticed the hole that leads to behind the wheel well was too small for the intake to fit through. i have only used short ram intakes (for water safty reasons) before, but i have heard of the problem i am having before so do i need to cut the sheet metal and if so what tool is best to use and how should i cut it. oh yeah i have a 97 base model.
Old Oct 8, 2003 | 02:25 PM
homesauce's Avatar
Default Re: aem cold air help (xALL MOTORx)
dremel that baby
Old Oct 8, 2003 | 03:26 PM
solowerks's Avatar
Default Re: aem cold air help (homesauce)
can't go wrong with the dremel
Old Oct 8, 2003 | 03:27 PM
Jon Like Wh0a's Avatar
Default Re: aem cold air help (solowerks)
if you dont' want to buy a dremel...you can go ghetto and just get some plyers and bend the metal so it'll fit around the tubing
Old Oct 8, 2003 | 03:32 PM
Default Re: aem cold air help (Jon Like Wh0a)
yeah im at school so i have very few tools with me so ghetto sounds like the way to go
Old Oct 8, 2003 | 04:16 PM
bad-monkey's Avatar
i took a drill and a hammer and some needlenoses. don't ask me how i did it, but it was done. i'm gonna go in there with a dremel and clean it up, later.
Old Oct 8, 2003 | 08:13 PM
Default Re: (bad-monkey)
thanks for the help guys i will let you know how it goes tomarrow
Old Oct 8, 2003 | 10:02 PM
homesauce's Avatar
Default Re: (xALL MOTORx)
or use a 3 dollar hack saw, that works too
Old Oct 8, 2003 | 10:06 PM
Matgallis's Avatar
Default Re: (homesauce)
double barrel shotgun works glorious
Old Oct 8, 2003 | 10:29 PM
PrecisionH23a's Avatar
Default Re: (92`Legend)
Make sure to line the rigid edges of the metal with stanpro (push on trim seal) so it does not cause wear on the intake piping. It also makes everything look nice and clean.
Old Oct 9, 2003 | 07:37 AM
93ludeSi's Avatar
Default Re: (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to line the rigid edges of the metal with stanpro (push on trim seal) so it does not cause wear on the intake piping. It also makes everything look nice and clean.</TD></TR></TABLE>
Good point, I have seen some with holes cut into the tube from rubing on he metal
findingeverland
34
Apr 27, 2007 08:27 PM
lude1888
Jun 16, 2006 04:04 PM
lude_si_95
Oct 9, 2003 07:42 AM
NAcivicEK
Apr 6, 2003 06:26 PM
raver69
Apr 6, 2003 04:51 PM
