OK to use Gunk on pistons?
Old Oct 8, 2003 | 01:34 PM
Hoosier Daddy's Avatar
Default OK to use Gunk on pistons?
EDIT: Nevermind...all cleaned up.
Is it OK to let the pistons soak in gunk overnight? What's the best way to clean the top?
Also, do I have to clean inside the ringlands? Tthe inner-most part where the rings sit.
Modified by Boost Creep at 6:43 PM 10/8/2003
Old Oct 8, 2003 | 08:15 PM
deepgreengsr's Avatar
Default Re: OK to use Gunk on pistons? (Boost Creep)
depends on what you are doing. when i put in used pistons I use a old ring i broke in half and grinded to a point. it fits perfectly in the slots and scrapes that crap off. use some carb cleaner. Its really reccomended to clean them if you are ballencing them.
sk8board{Pete}
Oct 19, 2008 12:07 PM
GSRCRXsi
Apr 23, 2007 03:30 AM
sshaikh01
May 20, 2003 05:45 PM
civicgsr91
Feb 2, 2003 06:33 PM
Smoothy
Jan 9, 2003 02:40 PM
