NEEDED- ABS plugs, relays from 98+ Integra
Just like the title says- here are the specifics-
-plug that goes to the ABS module in the back by right rear speaker
-plug that goes to the ABS modulator in front
- relays+plugs that are on the frame rail on the pass. side of the car, far forward
- plugs/wiring coming out of the ABS fusebox (located by the ABS modulator- near pass. front shocktower).
Ideally you'll be able to take out the whole ABS harness intact, but it it alright if you have to you can just give me plugs, I also have pics of everything+locations if you have any questions.
Thanks
Ben
Thanks
Ben
Turbohatch
25
Jan 3, 2003 02:02 PM
