Best turbo to make 400 hp on 15psi
Old Oct 8, 2003 | 05:32 AM
turbodsmpower's Avatar
Default Best turbo to make 400 hp on 15psi
Im trying to find specs i need to build a turbo to make about 400 hp on 15 psi. What turbo, A/r, trim, size wheel, housing ect for this setup. Motor is a b16 and will rev to about 8500 w/ it. Any Similar turbo that will work and the specs please list them
thanks
Old Oct 8, 2003 | 05:35 AM
Tinker219's Avatar
Default Re: Best turbo to make 400 hp on 15psi (turbodsmpower)
SC61, done. Contact ArTurbo for all the other info on it...
Old Oct 8, 2003 | 05:46 AM
VTC_CiViC's Avatar
Wow Abe, going big eh? lol
Old Oct 8, 2003 | 07:29 AM
Default Re: Best turbo to make 400 hp on 15psi (VTC_CiViC)
yah just want something to get the job done hehehe what the price on one of those
Old Oct 8, 2003 | 07:32 AM
T4eg's Avatar
Default Re: Best turbo to make 400 hp on 15psi (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">SC61, done. Contact ArTurbo for all the other info on it...</TD></TR></TABLE>
id agree also on the SC61.
Old Oct 8, 2003 | 07:47 AM
HotRodTeg's Avatar
Default Re: Best turbo to make 400 hp on 15psi (BlueHatch00)
with 15 psi we have made 455whp and 358 torque.
Old Oct 8, 2003 | 09:05 AM
15psi of fun's Avatar
Default Re: Best turbo to make 400 hp on 15psi (CrazyCompression)
i know it's been said but the SC61 will do it all day long
Old Oct 8, 2003 | 09:50 AM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyCompression &raquo;</TD></TR><TR><TD CLASS="quote">with 15 psi we have made 455whp and 358 torque.
Goddamn! Care to share some additional info?
Old Oct 8, 2003 | 10:01 AM
silverEH2's Avatar
Default Re: Best turbo to make 400 hp on 15psi (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
Goddamn! Care to share some additional info?</TD></TR></TABLE>
no ****
Old Oct 8, 2003 | 10:38 AM
Default Re: Best turbo to make 400 hp on 15psi (silverEH2)
yah what motor was that on and the setup details
Old Oct 8, 2003 | 10:40 AM
PM-Performance's Avatar
i think my turbo is more than worthy.
garret t3/04e 60 trim , 82 ex housing , stage 3 wheel . we were estimating mine close to 400 maybe a little less on 12 psi , it was pretty sick when it was running
Old Oct 8, 2003 | 11:01 AM
InTeGrA B18b1's Avatar
Default Re: Best turbo to make 400 hp on 15psi (itr206)
cost 700-1000 for the turbo
Old Oct 8, 2003 | 11:05 AM
PrecisionH23a's Avatar
You must have been running some crazy compression huh. ba-dum-chhhhh
I am not doubting you at all, but I have heard so many people say they have made over 400 at low boost pressures but cannot back up their stories with a dyno. Anyways, I'm interested in hearing about the set-up if you care to share...
I am also a fan of the sc61
Old Oct 8, 2003 | 11:16 AM
turbo*s2k's Avatar
I'm assuming the SC61 is a ball bearing type turbo??? At what RPM would you start seeing boost with the SC61? Does it have good low end and top end power?
Old Oct 8, 2003 | 11:59 AM
TeStUdO's Avatar
Default Re: Best turbo to make 400 hp on 15psi (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming the SC61 is a ball bearing type turbo??? At what RPM would you start seeing boost with the SC61? Does it have good low end and top end power?</TD></TR></TABLE>
depending on your trim and motor......most people see full boost around 4500-5500rpm's
Old Oct 8, 2003 | 12:35 PM
93LSivic's Avatar
Nope, not ball bearing. I get 11 psi around 4200 or so. Starts to boost around 2900. This is on 81mm 9.2ish compression. It pulls hard up to reline. My torque curve is pretty flat from 5000 to 7000---i want t add more timing to get the tq from falling off after 7k next time at the dyno.
Here is my chart. Its pretty small but reads 321whp and 236tq
Old Oct 8, 2003 | 02:37 PM
turbo*s2k's Avatar
Thanks for the info. How would the SC61 compare to a t3/tO4e 57 trim, .63 AR housing, stage 3 exhaust wheel? or can you not compare the two...
Old Oct 8, 2003 | 03:14 PM
Kack's Avatar
the SC61 is bigger
Old Oct 8, 2003 | 07:15 PM
turbo*s2k's Avatar
Default Re: Best turbo to make 400 hp on 15psi (Kack)
thanks!
BlueSi2k
Aug 23, 2007 01:24 PM
high_octane
Jul 14, 2007 09:32 AM
JDM_rolex
Apr 8, 2006 11:18 PM
chex329
Oct 24, 2005 01:28 PM
BiG DaDDy O
13
Sep 23, 2004 04:23 PM
