H22a or B18c5
Old Oct 7, 2003 | 09:23 PM
KenRed's Avatar
Default H22a or B18c5
Ok I need a opinion on a engine. I have a 97 EX Civic and I was wonderin between the B18c5 and H22a which is the better engine and can handle turbo better? cause I know the JDM motor is about 220hp and the B18c5 is about 195hp so if u can help me im me on aol@ dsgb316.
Old Oct 7, 2003 | 10:10 PM
Senbonzakura's Avatar
Default Re: H22a or B18c5 (KenRed)
They will either flame you for this or use the search.
B18C5 or the Type R has a high compression level. You can turbo it if you want but people suggest low compression. H22a the luders engine is the samething, correct me if i'm wrong on this.
Old Oct 7, 2003 | 10:21 PM
Full-Race Henry's Avatar
i personally dont like h series motors. i would just stick with a b series. but the type r's comression is pretty high, go with a gsr or lsvtec turbo.
Old Oct 7, 2003 | 10:25 PM
UnionCity LS's Avatar
Default Re: H22a or B18c5 (EF8_Fan)
id also stick with the B series engines...
Old Oct 7, 2003 | 10:26 PM
P1mpSlap's Avatar
Default Re: H22a or B18c5 (Kyo Kusanagi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyo Kusanagi &raquo;</TD></TR><TR><TD CLASS="quote">They will either flame you for this or use the search.
B18C5 or the Type R has a high compression level. You can turbo it if you want but people suggest low compression. H22a the luders engine is the samething, correct me if i'm wrong on this.</TD></TR></TABLE>
dude you so gotta get a new avatar
Old Oct 7, 2003 | 10:48 PM
Mainevent's Avatar
Default Re: H22a or B18c5 (P1mpSlap)
How about all honduhs have no tourque and you drive plastic pieces of ****.
Old Oct 7, 2003 | 10:56 PM
N1NjA TuRtLE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
dude you so gotta get a new avatar</TD></TR></TABLE>
AHAHAAHHAHHHHAHAAHAHAHHAHAHAHAHAHHAHHHHHAAHAHHAHAA HHAAH
v99h22
Apr 18, 2013 06:34 AM
type-t
Aug 25, 2004 09:36 PM
.:Swig:.
Apr 19, 2004 11:18 PM
Showoffnyc1
Oct 29, 2002 12:18 AM
ZXVIIR
Oct 13, 2002 07:38 PM
