I Need Help Hooking Up A Heater Control
Old Oct 7, 2003 | 08:24 PM
STHPERFORMANCE's Avatar
Default I Need Help Hooking Up A Heater Control
Ok, on the back on the heater control there are several cables....
Cold-Hot select has two cables
Inside-outside vent has one cable
Air position selection has one cable
What i need help with is to where exactly do these cables go? I was told one go to the heat valve on the firewall but the resource wasnt 100% sure.
Keep in mind...... i have no A/c ......
Old Oct 7, 2003 | 08:53 PM
Default Re: I Need Help Hooking Up A Heater Control (Outkast)
To The Top........
Old Oct 8, 2003 | 05:24 AM
keithv's Avatar
i'm pretty sure the cold-hot cable goes to the valve that is in the engine bay. as for the others, i forget where they go.
Old Oct 8, 2003 | 08:02 AM
Default Re: I Need Help Hooking Up A Heater Control (keithv)
To the top....
Old Oct 8, 2003 | 01:25 PM
To the top.... does anyone know ?? ANYONE!!!!!
Old Oct 8, 2003 | 09:01 PM
Up for the night crew......
Old Oct 9, 2003 | 06:33 AM
sporkcrx's Avatar
The cold/hot **** has two cables that go to the heater valve just past the firewall.
Old Oct 9, 2003 | 06:36 AM
Default Re: I Need Help Hooking Up A Heater Control (sporkcrx)
i was told by honda that only one of those cables from the hot-cool select go to the heater valve on the firewall.......
To The Top.....
Old Oct 9, 2003 | 11:14 AM
sporkcrx's Avatar
****, I'm trying to remember. Maybe it is only one cable that goes to the hot/cold ****. I'll see if I can find anything in the book.
Old Oct 9, 2003 | 02:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">****, I'm trying to remember. Maybe it is only one cable that goes to the hot/cold ****. I'll see if I can find anything in the book.</TD></TR></TABLE>
kewl
Old Oct 9, 2003 | 02:54 PM
sporkcrx's Avatar
Ok, I don't have a scanner so I took some digi pics of the parts I could find that showed what you're talking about. Tell me if it helps.
http://www.norcalcrx.org/spoon2/pics/heater1.jpg
http://www.norcalcrx.org/spoon2/pics/heater2.jpg
http://www.norcalcrx.org/spoon2/pics/heater3.jpg
http://www.norcalcrx.org/spoon2/pics/heater4.jpg
Old Oct 9, 2003 | 05:36 PM
Good pics, But those just show where the cables attach on the heater control....
I have the cables all attached to the heater control, i just need to know witch cables go where in the car... I appriciate the pics though
Old Oct 9, 2003 | 05:38 PM
crxforum's Avatar
Ignore this I read your post wrong.
CRX Forum
Old Oct 9, 2003 | 09:10 PM
Default Re: I Need Help Hooking Up A Heater Control (crxforum)
To The Top.........
Old Oct 10, 2003 | 04:50 AM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast &raquo;</TD></TR><TR><TD CLASS="quote">i just need to know witch cables go where in the car... I appriciate the pics though </TD></TR></TABLE>
elaborate.
Old Oct 10, 2003 | 06:06 AM
CRneXt's Avatar
On my EF, I only have ONE CABLE.
It is the one that moves when you turn the heat control. The range selector will move when you got from vent to floor to defrost. It goes to the exchanger right beside the gas pedal. The other one goes to fresh air/recirc on top of the blower motor. I know all these, because I had to swap my exchanger just last week. my heater core got damaged, when I tried to change the hoses from the block and intake manny.
I hope that this helps, if I am too vague about any of this IM me. I THINK you are gonna have to pull the dash cap for this 'un.
Scott
Old Oct 10, 2003 | 07:38 AM
Default Re: I Need Help Hooking Up A Heater Control (CRneXt)
Last night i went out and tested my luck...... To say the least..... I have heat and she works perfectly fine..... Thanks everyone
navcc
Apr 28, 2013 01:33 PM
prelude_93vtec
Nov 16, 2008 08:13 AM
jmar97
Dec 13, 2004 10:51 AM
crxhoutx
May 4, 2004 07:00 PM
STHPERFORMANCE
Oct 8, 2003 08:12 AM
