JDM fogs don't work anymore!!!!!!!!!!!
Old Aug 29, 2001 | 07:23 AM
Calvin Lai's Avatar
New User
Default JDM fogs don't work anymore!!!!!!!!!!!
I finally got around to putting in H3 bulbs into my JDM fogs last nite and do the mod. This is what I did...
I crimp a male spade connector to one end of an 18 gauge wire. With the other end, I use the screw which is in contact with the clip/holder (which in turn is in contact with the bulb when u "lock" the bulb in place) on the housing and screw in the wire. I plug the spade connector into the ground on the harness coming from the car and I plug the connector of the h3 into the + on the harness coming from the car.
Result: doesn't work .
I plug in the stock H3C back to the harness without using the housing (don't think it matters). Doesnt' work anymore. I thought I've blown a fuse. According to my prelude hand book, there's a 15 amp fuse for the fogs. So I checked that but it isn't blown at all.
Any ideas????????????????????????????????????????????? ? Am I doing something wrong here?
Old Aug 31, 2001 | 09:12 AM
prelude1897's Avatar
Default Re: JDM fogs don't work anymore!!!!!!!!!!! (Calvin Lai)
Might want to check your bulbs themselves. You may have burnt out the bulb. If that isn't the problem, then check the wiring again.
Old Aug 31, 2001 | 06:01 PM
98 Ek LsVtec's Avatar
Banned
Default Re: JDM fogs don't work anymore!!!!!!!!!!! (prelude1897)
maybe a bad ground
i've installed some before there pertty simple so i would just disconnect everything and reinstall them
champ421
Lighting
Jan 6, 2015 08:43 PM
Pr-Type-R
Mar 10, 2009 08:56 PM
cfran55
Jun 12, 2005 11:45 AM
