Intake hose to air box spring clamp
Old Aug 29, 2001 | 07:00 AM
ITR_1211's Avatar
Default Intake hose to air box spring clamp
How do you guys remove the "spring clamp" on the intake hose?
It is the one connected to the air box assembly.
Thanks.
Old Aug 29, 2001 | 07:03 AM
Bob#455's Avatar
Default Re: Intake hose to air box spring clamp (Darryl Mussashi)
Look close and you will see where the two ends of the spring clamp meet....just use two pairs of needle nose pliers to separate it. If you're careful, you should be able to use it again. BTW, you can take the filter on and off with the spring attached.
[Modified by Bob#497, 8:05 AM 8/29/2001]
Old Aug 29, 2001 | 07:53 AM
yoshi234's Avatar
I shoot brides
Default Re: Intake hose to air box spring clamp (Bob#497)
look underneath and you'll see the part where bob talked about above.
I wouldn't take it off though...it's beotch to put it back on
Old Aug 29, 2001 | 08:20 AM
ITR_1211's Avatar
Default Re: Intake hose to air box spring clamp (yoshi234)
If you don't take it off how are you suppose to change the air filter?
Old Aug 29, 2001 | 08:23 AM
Willard's Avatar
the h0ze slides off of the filter end with-out much effort.
getting it back on is another story.
Will
Old Aug 29, 2001 | 08:26 AM
Toda Party's Avatar
Default Re: Intake hose to air box spring clamp (Willard)
i took mine off and i lost it. so i just used a regular clamp to put it back on. it works fine
Old Aug 29, 2001 | 09:05 AM
ITR_1211's Avatar
Default Re: Intake hose to air box spring clamp (NBP ITR 01-622)
I guess the intake pipe from comptech would be the best solution. My spring clamp actually gauged a bit of the intake hose
Does anyone know if I just get the intake pipe it would fit on the stock air box? Dealer wants $70 just for the hose!
Old Aug 29, 2001 | 03:41 PM
ITR_1211's Avatar
I just got confirmation from comptechusa that the pipe won't fit on the stock air box. I can't stand looking at my gouged intake hose its driving me nuts! so I just ordered one from the dealer
Does anyone have any other suggestions? Other than me seeing a doctor?
Old Aug 29, 2001 | 04:38 PM
mugenr#1011's Avatar
hey when i put my mugen intake on i didnt even take it off..it just went back in..with a little work. maybe it was easy cuz the intake has that tube that goes into hose..are you getting a new intake? good luck..mugen
CHu Chu
May 17, 2009 08:15 PM
vmm
27
Jul 17, 2004 09:15 PM
thk
Feb 20, 2002 06:08 PM
Tommy_Gunns
Jul 23, 2001 01:23 PM
