cr on an ls/vtec?
Old Oct 7, 2003 | 07:26 PM
streetlvlhatch's Avatar
Default cr on an ls/vtec?
I am building a ls/vtec and am wondering what would be a safe cr for the street. What pistons would be the best choice, i cant decide cause there is so many choices.
Old Oct 7, 2003 | 07:33 PM
-KangaRod-'s Avatar
I'd say go with either a P73-A00 piston (usdm ITR) (10.85:1 compression w/ B16 head and OB piston) or a PR3 piston (first gen b16)(11.33:1 w/b16 head and SB piston) or if you are going with Hondata or a standalone to go with PCT (JDM CTR pistons) (12.03:1 w/ b16 head and OB piston).
Both the CTR and ITR piston sets would cost around $175 new, where as the PR3 would cast about $50 but would be used. PR3 is a good option if cost is an issue. ITR is a good option if compression is an issue, CTR is a good option period!
Old Oct 7, 2003 | 08:16 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: cr on an ls/vtec? (streetlvlhatch)
I'd say go with the search button. Then follow it up with just reading this forum. This quesiton hase probably been asked twice on this page alone.
Old Oct 13, 2003 | 07:11 PM
i just recently dropped my block off to the machine shop to get honed (or bored depending on measurements) and they said not to go over 10:1 on pump gas. Now i know that is a little low but ctr pistons seem a little high (12.4:1) I want to know what a reasonable amount was. I looked at SRP pistons that would put it at 10.6:1. Is higher ok? remember i want this as streetable as possible
thanks
Old Oct 13, 2003 | 07:18 PM
riceball777's Avatar
i'm building my ls vtec with a b16 head and i want as much compression as i can with pump gas (91 octane)
ctr's would be to high (12.1) so i'm going with p30(11.5) which i think yeilds the best cr on a daily driven car on 91 octane
i would say either go with pr3(11.3cr) or p30(11.5) this is assuming your going with a b16 head
Old Oct 19, 2003 | 05:45 PM
Default Re: cr on an ls/vtec? (riceball777)
i prolly will buy itr pistons which i think bump the cr to 11.2 to 1? right? will this be fine on pump gas
Battle Cat
Apr 16, 2005 02:51 PM
JDubya
Feb 21, 2003 09:56 AM
racer4life
Feb 14, 2003 12:02 PM
-Racer X-
Apr 8, 2002 06:16 PM
MXPX
Jun 20, 2001 06:33 PM
