Prefered oil grade?
Old Oct 7, 2003 | 07:08 PM
xstalkrx's Avatar
Default Prefered oil grade?
I do not have a acura manual. For a 94 GSR at 109K miles in Dallas, Texas area. What grade of oil is best for all year round use?
If synthetic oils are better, which grade in synthetic should I get? Thanks.
Old Oct 7, 2003 | 07:20 PM
oMek's Avatar
Default Re: Prefered oil grade? (xstalkrx)
well i have 149k i just switched to synthetic and i love it. ide get a 5w-30 or a 10w-30. just depends how much you wana spend every time you change your oil. if you go synethitic ide get moble1. if you go dyno get castrol GTX
Old Oct 7, 2003 | 07:21 PM
B16OnTop's Avatar
i use 10W30 in my LSVTEC teg, feels alot better then whatever the previous owner was putting in there
Old Oct 7, 2003 | 09:55 PM
xteg95's Avatar
Default Re: Prefered oil grade? (B16OnTop)
5w30 < 40 degree weather (winter mostly) and 10w30 any other time.
Old Oct 7, 2003 | 11:02 PM
NuclearB18B's Avatar
Default Re: Prefered oil grade? (xteg01)
i use mobile one 15w-50
Old Oct 7, 2003 | 11:05 PM
P1mpSlap's Avatar
10w30 castrol gtx syntec
Old Oct 7, 2003 | 11:07 PM
WhitEdRift's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">10w30 castrol gtx syntec</TD></TR></TABLE>
I second that. The owner's manual recommends 10w30, althought I have 20w50 right now I am going to switch next change.
Old Oct 8, 2003 | 05:31 AM
IntEGNYC's Avatar
Default Re: (WhitEdRift)
10W30 here in the four seasons weather in NYC.
Old Oct 8, 2003 | 05:52 AM
tachyteg's Avatar
Default Re: (IntEGNYC)
5W30 in my 99 gizzer
Old Oct 8, 2003 | 08:54 AM
wall of tvs's Avatar
Default Re: (tachyteg)
The manual states that 5w-30 is the recommended grade of oil.
Go with Valvoline Max Life 5w-30 with oem Honda filters, and you'll be a happy camper
Old Oct 8, 2003 | 10:30 AM
TEXN3's Avatar
Default Re: (wall of tvs)
if you go syn...use mobil 1. otherwise use honda oil(a product of mobil). i use 10w-30 year round now, mainly because the motor is getting older and the rings are getting tired and a little thicker oil helps.
Old Oct 8, 2003 | 10:59 AM
quikB18B's Avatar
Default Re: (texnteg)
Mobil 1 10w30, honda oil filter every 2500 miles in Dallas
Old Oct 8, 2003 | 12:16 PM
IntegraB18A's Avatar
i use 10 w/ 30 in miami, fl
Old Oct 8, 2003 | 01:34 PM
Boostin95Teg's Avatar
Default Re: (IntegraB18A)
valvoline synthetic here...5w-30
Old Oct 8, 2003 | 01:40 PM
juggernaut's Avatar
When I was stationed in AZ I used 10w 30 all year round never had a prob.
Old Oct 8, 2003 | 03:55 PM
xstalkrx's Avatar
Do you buy your oils at auto zone, or other local all purpose part shops? What about your oil filters?
Old Oct 8, 2003 | 04:59 PM
TEXN3's Avatar
i buy my oil and filter from the honda dealership. the cost totals to about 15 bucks. or i get the change done there for 21.99. you can get your oil at an autoparts store. go with a wix filter, IMO. they are very good. but, good luck changing the filter on your integra. it is a bitch to get too, even with a filter wrench. its worth spending the money to get it done by someone with a lift.
Old Oct 9, 2003 | 09:10 AM
WhitEdRift's Avatar
Default Re: Prefered oil grade? (texnteg)
I just use my hand to unscrew the filters when I do oil jobs. It is usually a little messier since the oil drips down for a minute or two but just put some news paper and an oil pan underneath.
As long as whoever put it on before oiled the filter gasket it should come off smooth, and don't tighten it too much putting it back on.
Old Oct 9, 2003 | 09:16 AM
IntEGNYC's Avatar
Default Re: Prefered oil grade? (WhitEdRift)
remember to wear a long sleeved shirt when working with the oil filter just so that you dont get burned.
bobmugen
Mar 11, 2008 07:45 AM
NeriVTEC
Dec 22, 2005 01:55 PM
jimbob2
Acura TL, RL & ZDX
Jan 10, 2004 10:55 AM
B18cteg
May 29, 2003 05:09 PM
FBP Ex-T
Feb 6, 2002 09:25 AM
