toda question for b16
Old Oct 7, 2003 | 06:39 PM
jaydmcrx's Avatar
Default toda question for b16
What kind of power gains do you guys think I could get out of a toda stroker kit, with a b16a1? I know its alot of money, but I was just curious as to what kind of power I could produce?
Old Oct 7, 2003 | 08:32 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: toda question for b16 (jaydmcrx)
Think of it as an 11:1 compression GSR motor with a poor R/S ratio. You'd be better off building a GSR block. Or if you really wanted to you could go a B17A crank and sleeve to 85mm and run 12:1 compression in your B16A and have a 1.85L with an awesome R/S ratio (not that it really matters) and make more power.
Old Oct 8, 2003 | 10:27 AM
jaydmcrx's Avatar
thats not a bad idea to be honest with you.....i even talked to the guy at inline four and he said that it is only good for what it is???doesnt sound like he is too confident to me about it so maybe ill go that route. What sleeves would you reccomend? I was gonna go with golden eagle with some je pistons. But then where do I go for the head gasket? Any suggestions for the rods? And where the hell do I get a b17 crank? Oh and could I use a type r crank or anything of that sort?
Old Oct 8, 2003 | 12:41 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (jaydmcrx)
GEM, AEBS, Benson, RS Machines, Dart all good. Cometic head gasket. 85mm $79.95. Crower is the only one that makes B17A connecting rods OTS that I've found. I plan on using these. Good luck sourcing a B17A crank not new. It's challanging to say the least. The ITR/GSR crank is the same 87.2mm crank that comes in the TODA stroker kit, so you're back to that again.
Old Oct 8, 2003 | 07:29 PM
jaydmcrx's Avatar
Default Re: (Mr Milano)
thanks for the input man....I think I'm going to do all that but the b17 crank and keep my b16 crank. If I come across one that would be great, but I dont think im gonna hunt one down.
Old Oct 8, 2003 | 08:19 PM
GreenR's Avatar
use a LS crank.
Old Oct 8, 2003 | 09:08 PM
ill phil's Avatar
Default Re: (GreenR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenR &raquo;</TD></TR><TR><TD CLASS="quote">use a LS crank.</TD></TR></TABLE>
Not a drop in for a b16a sorry.
Old Oct 10, 2003 | 07:52 AM
jaydmcrx's Avatar
I have seen people use them in b16's tho and it made really good horse power. All stock b16 with ls crank in a gutted crx hf ran a 13. 6. Not too bad, I dont know what they had to do to make it work tho?
Old Oct 10, 2003 | 08:20 AM
JCushing's Avatar
dont you need a deck plate for the ls crank in the b16?
Old Oct 10, 2003 | 01:33 PM
ill phil's Avatar
Default Re: (JCushing)
I would think deckplate or custom rods and pistons.
Old Oct 10, 2003 | 02:20 PM
thegrinch's Avatar
My fiance's car made 185whp and 120tq with toda b's. stock bottom end...
peak power was at 9k
Unfortunately she lost a valve due to fatige.
The car should make 200whp with more compression nad p&p head
vtec8200
14
Oct 24, 2011 06:01 PM
Chris Benoit
Oct 25, 2005 09:32 AM
erck19
Oct 3, 2003 10:19 PM
jaydmcrx
Sep 27, 2003 05:50 PM
Darkteg
Mar 19, 2003 09:43 AM
