2003 Accord radio removal
I doubt anybody here has tried it on the 7th gen yet. Try talking to some audio shops
if you have a 6th gen then all you do is pop out the clock remove the screw behind it. Then below the black surround you will see two phillips head screws remove those and pull it out gently, after you have done that you should be able to figure out the rest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman »</TD></TR><TR><TD CLASS="quote">I doubt anybody here has tried it on the 7th gen yet. Try talking to some audio shops
if you have a 6th gen then all you do is pop out the clock remove the screw behind it. Then below the black surround you will see two phillips head screws remove those and pull it out gently, after you have done that you should be able to figure out the rest.</TD></TR></TABLE>
are u sure on that?
anyways, i work at honda dealership,,,,,and i pop out 7th genth accord a lot of times already......i tell you.....first time doing it.....scratch up everything...(yes it is a bitch)
direction: im sorry, i would not discribe, members might try and blame it on me :9
bye
are u sure on that?
bye
88ernie88
13
Apr 5, 2009 12:31 AM
Ideal
Audio / Security / Video
Aug 15, 2002 07:00 PM
