Does changing your Final Drive change the odometer reading?
Old Oct 7, 2003 | 03:23 PM
typer 00-115's Avatar
Default Does changing your Final Drive change the odometer reading?
If you change it will it affect the speedo and odo like changing your tire size?
Old Oct 7, 2003 | 03:25 PM
IntegraGSR23's Avatar
Default Re: Does changing your Final Drive change the odometer reading? (typer 00-115)
Only RPM I would think
Old Oct 7, 2003 | 03:29 PM
does anyone know for sure
Old Oct 7, 2003 | 03:31 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer 00-115 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know for sure</TD></TR></TABLE>
It will not change MPH reading, odometer, trip, etc.
Old Oct 7, 2003 | 03:36 PM
1GreyTeg's Avatar
Default Re: Does changing your Final Drive change the odometer reading? (ElKamino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ElKamino &raquo;</TD></TR><TR><TD CLASS="quote">
It will not change MPH reading, odometer, trip, etc. </TD></TR></TABLE>
Correct, and I know for sure.
Old Oct 7, 2003 | 03:40 PM
Default Re: Does changing your Final Drive change the odometer reading? (1GreyTeg)
Can you explain how it doesn't? (said in a nice voice please don't be defensive) Im trying to figure out in my head, how the speed sensor would be affected by the FD
Old Oct 7, 2003 | 03:44 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
I am guessing the drive gear on the diff. for the speedo. is the same as the one you are replacing.
The wheels are still spinning at the same rate just different gear ratios, and final drive ratio, which affects rpm for given speed.
Old Oct 7, 2003 | 04:03 PM
Dr Pooface's Avatar
Default Re: (v-attack)
I believe the speed sensor is attached to the diff, which is after the ring gear and spins with the wheels.
Old Oct 7, 2003 | 04:04 PM
1GreyTeg's Avatar
https://honda-tech.com/zerothread?id=593564
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">because speed is measured by how manytimes the differential turns.
if you somehow made the diff larger diam or smaller diameter then it would mess something up. </TD></TR></TABLE>
Search is your friend.
And also because I have an aftermarket FD and checked this before I had it installed.
Modified by 1GreyTeg at 6:55 PM 10/7/2003
Old Oct 7, 2003 | 05:08 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=593564
And also because I have an aftermarket FD and checked this before I had it installed.</TD></TR></TABLE>
Old Oct 7, 2003 | 05:16 PM
1OPTION's Avatar
Agreed, 98% sure.
Old Oct 7, 2003 | 06:30 PM
Dave-ROR's Avatar
Default Re: Does changing your Final Drive change the odometer reading? (1OPTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1OPTION &raquo;</TD></TR><TR><TD CLASS="quote">Agreed, 98% sure.</TD></TR></TABLE>
98%? nah, it's 100% fact.
Old Oct 7, 2003 | 06:47 PM
PlikityPLAH's Avatar
what part of phoenix you at? i am in scottsdale, i havent really met another R owner in az yet...
Old Oct 7, 2003 | 09:36 PM
Rob Dizzle's Avatar
Default Re: Does changing your Final Drive change the odometer reading? (IntegraGSR23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGSR23 &raquo;</TD></TR><TR><TD CLASS="quote">Only RPM I would think</TD></TR></TABLE>
ok thanks for teh good info there buddy.
doesnt change speedo or anythign else.
Old Oct 8, 2003 | 07:41 AM
DsITR's Avatar
The idea behind the speed sensor..is..well it senses speed of course. So if your FD changes, the speed sensor accounts for it.
mugenintegra16
Honda S2000
18
Aug 28, 2008 11:58 AM
seed2harvest
Honda Civic (2006 - 2015)
May 28, 2007 07:32 PM
Solo2Vtec
13
Mar 23, 2007 10:50 AM
zentraedityper
Dec 17, 2003 07:15 PM
crj_lll
Nov 19, 2003 07:13 AM
