One of those si tranny questions.
Old Oct 7, 2003 | 12:32 PM
brent_G's Avatar
Default One of those si tranny questions.
Alright i searched now for about 45 mins on here...but i still am not postive about a few things.
Heres the deal. Right now i have an 88 si tranny with act clutch. Has a leak tho. So im gonna be running an 89 si tranny that is in better condition. I know i cant use the clutch from the 88.
But here is the question. Someone told me i could use a 92-00 flywheel with the 89 tranny.
The question is...is that true, and if i can use that flywheel what clutch should i use with it? the 89? the 92-00?
I HOpe that wanst too confusing...please get back to me THanks
Old Oct 7, 2003 | 12:35 PM
EL Vap133's Avatar
Default Re: One of those si tranny questions. (screamincivik)
Get the 89 flywheel and clutch disk.
Old Oct 7, 2003 | 12:52 PM
davens's Avatar
I don't know about 92-00 but I used a 90-91 clutch/flywheel on my 89 tranny
Old Oct 7, 2003 | 01:00 PM
brent_G's Avatar
Default Re: (davens)
Im also running a d16z6 in my crx...dunno if that makes a difference?
Old Oct 7, 2003 | 02:22 PM
scratchline20's Avatar
Default Re: (screamincivik)
I know you can upgrade to the 90-91 flywheel and use a 90-91 clutch. If you use an 89 flywheel, you need an 89 clutch. The 89 clutch is a little smaller than the 90-91 and it can't hold as much power. I don't know about putting the 92-00 flywheel in though.
Old Oct 7, 2003 | 04:20 PM
brent_G's Avatar
Default Re: (scratchline20)
thanks a ton so far guys, just wannna make sure we have the same consensus around the board bump
Old Oct 7, 2003 | 04:49 PM
brent_G's Avatar
ALSO i have a cx flywheel that i might shave...would i be able to use this with the 89 si tranny?
Old Oct 7, 2003 | 06:19 PM
ShiroX's Avatar
90-00 is the same size for all SOHC motors
in 1990 the crx came with a slightly larger Flywheel than the 89
so if you get an 89 tranny try and located a 90-00 flywheel so you can run any 90-00 clutch setup
all SOHC trannys from 89-00 have 20spline input shafts and can share the same clutch
the 88 however has a 21 spline input shaft
For reference though people with 88 Trannys that want to upgrade to the larger clutch can use the 90-00 flywheel but will need to order an 86-89 ACCORD clutch disc
the 86-89 ACCORD disc are 21 spline but have the larger 90-00 diameter of the later SOHC setups
Old Oct 7, 2003 | 06:37 PM
Snowboarding EF's Avatar
Default Re: (VTeC4TheChildren)
yep
Old Oct 7, 2003 | 07:52 PM
brent_G's Avatar
Default Re: (Snowboarding EF)
alright that was my biggest concern was if i could use the 90-00 flywheel and clutch with the 89 tranny. I appreciate the help.
CRXalwysk8
13
May 3, 2005 07:18 AM
sykohatch
Aug 16, 2004 08:51 PM
FlexW99
Feb 27, 2004 11:51 AM
nuc79
Feb 1, 2004 08:21 PM
.ShawnD.
Nov 9, 2002 08:41 AM
