lost flywheel splash guard - flywheel exposed, any damage?
well I crawled under the car to remove the heat shield since it was rattling like crazy and weeee! I noticed that the flywheel was exposed, apparently the flywheel splash guard/cover is lost. I'll need to get it replaced but just out of curiousity: what kind of damage am I looking at without the flywheel cover? I have no idea how it work and I was wondering if I need to have the tranny fluid replaced after I replace the flywheel cover?
Are you talking about the thin metal cover that goes between the engine stiffiners and the transmission?
I would think that dirt and water getting into the clutch housing area might cause damage to the clutch assembly, bearings and could cause the flywheel and the steel parts of the clutch and pressure plate to rust. Not good...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless »</TD></TR><TR><TD CLASS="quote">what should I do right now? just get it covered up?</TD></TR></TABLE>
dude go buy another one.
Dirt really isn't that much of an issues as some forgien object flying up in there and ******* up the clutch.
your fine for a while. even with the cover junk can still get up there. just take it easy till you get a new cover.
I would probably drive another car till you have a replacement to install.... not worth the possibility of damage.
Jason
Jason
found a replacement, thanks to honda tech, do you guys know the bolt length/ thread pattern for it? I want to go to the hardware store to pick them out
maybe thats another reason y my cm stage 4 burnt up lol
performance was great during that 9 months.. just thought it would of lasted like a yr or somthin
mine's been off for a year..i just bought the plate and all bolts needed from acura...then looked and i'll have to take off my header i just put on..too much trouble to deal with right now..if you want the acura #'s for the bolts IM me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless »</TD></TR><TR><TD CLASS="quote">bolt pattern please?</TD></TR></TABLE>
just penny up and go with a
or
bolt.. why mess around trying to match thread patterns
or
immalooser
Oct 18, 2005 08:08 PM
