Redrilling 4x100 to 5x114.3 a bad idea?
Old Oct 7, 2003 | 11:12 AM
Bnjmn's Avatar
Default Redrilling 4x100 to 5x114.3 a bad idea?
Is redrilling a disc/rotor hat from 4 x 100 to 5 x 114.3 a bad idea? I thought this was common practice for people doing the cheap ITR brake upgrade with Prelude discs. I took my 4 lug StopTech hats to a machine shop and they weren't too interested in re-drilling the bolt pattern.
Thanks
Ben
Old Oct 7, 2003 | 12:22 PM
-tim's Avatar
Default Re: Redrilling 4x100 to 5x114.3 a bad idea? (Bnjmn)
well ive known a few people who have done this with no problems to this day...
me personally.. i wouldnt do it, maybe let a profesiional do it and measure it up perfect.
actually, the people i know who have done re-drilling went from 5 lug to 4 lug,
both were putting mugen active gate brake sys. on there 4 lug civics.......
let me know how it turns out.. and good luck
Old Oct 7, 2003 | 12:24 PM
Bnjmn's Avatar
Default Re: Redrilling 4x100 to 5x114.3 a bad idea? (brown wheels)
Thanks. I definitely wouldn't do it by myself. The hat on the StopTech setup is a bit thinner than the stock one piece hat/rotor. Does anyone have any pics of what the re-drilled setup looks like?
Thanks
Ben
Old Oct 7, 2003 | 12:44 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Is redrilling a disc/rotor hat from 4 x 100 to 5 x 114.3 a bad idea? I thought this was common practice for people doing the cheap ITR brake upgrade with Prelude discs. I took my 4 lug StopTech hats to a machine shop and they weren't too interested in re-drilling the bolt pattern.
Thanks
Ben</TD></TR></TABLE>
its possible...
The only real downside you should keep in mind, is that cracking may occur over time, mainly at the lug hole(s) area since you'll be slightly swiss-cheesing the rotor. Depending on how far apart the new holes will be drilled, making more holes (in the lug area of the rotor) will make it less rigid since you're taking away from the spacing between the factory holes. So cracking may occur between the factory holes & the newly drilled holes...
Hope that all makes sense. lol..
btw, hit up FASTBRAKES.COM for information on doing the cheap big brake upgrade (prelude rotor redrill etc)
Russki
Apr 15, 2016 09:15 PM
apm
Apr 24, 2006 08:15 AM
xHONORTHEBRANDx
Nov 15, 2005 05:23 AM
inty2511
May 28, 2003 05:53 AM
