civic seat question
Old Oct 7, 2003 | 07:39 AM
SamuelK's Avatar
Default civic seat question
i have a 88 honda civic hatch DX, i was interested in buying new seats but i need to know what seats can fit??
I already bought a pair of CRX Si seats but they didn't mount up even after attemping to switch the railing, any help would be nice
-Thanx
Old Oct 7, 2003 | 08:16 AM
1st-hybrid's Avatar
Default Re: civic seat question (Hatchin)
I'm not too sure but I think some of the later ones won't work unless you make soem custom mounts. And the crx seats have a much more narrow pan and rail than the civics do.
Old Oct 7, 2003 | 09:12 AM
CarAudiophile's Avatar
Default Re: civic seat question (1st-hybrid)
I have the same kinda question.. I have a set of 90 Si seats I want to put in my 89 DX and I can't get them sob's in my 89.. I looks like I got to do some cutting but not sure. The back seat went in with ease..
Old Oct 7, 2003 | 09:54 AM
SamuelK's Avatar
Default Re: civic seat question (CarAudiophile)
yea, so anyone else on here have a seat swap?
Old Oct 9, 2003 | 11:25 PM
SpoonSleeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchin &raquo;</TD></TR><TR><TD CLASS="quote">yea, so anyone else on here have a seat swap?</TD></TR></TABLE>
I have 95 Lude seats in my EF.
Old Oct 9, 2003 | 11:28 PM
Smokinsax's Avatar
The Boot
Default Re: civic seat question (SpoonSleeper)
I know there are a lot of differences between the 88-89 models and 90-91. This may be one of those differences. What year Si seats do you have?
Old Oct 10, 2003 | 01:19 AM
USDM 4G VTEC's Avatar
i have HF CRX seats into my 90 STD&gt;.....
i custom made some brackets.....
i am in ohio...... ill sell ya 92-95 civic seats in fair good condition for 40 bucks...
Old Oct 10, 2003 | 01:31 AM
sweetcarz02's Avatar
I got JDM seats, I just took the USDM brackets, stuck them on the JDM seats and did a little bit of modifications and they fit fine, due to the odd fitting of the CRX seats I am pretty sure all seat swaps will take a little bit of modifications, it's nothing u cannot handle on your own, don't be scared
Old Oct 10, 2003 | 01:52 AM
Mrock's Avatar
Default Re: (sweetcarz.com)
I have Si seats in my 91' DX. I'm not sure of what year they are, because I bought them off some guy, with not much info. Here's what I did...
1) Unbolt the original rails off the seats that are curently on..
2) Unbolt the Si seat rails.
I then tried to bolt the Si seat to the original frame rails, and saw where it did not match up. I then drilled a hole or two, to make it fit. This step took the longest..because my drill battery kept going dead, but basically the trick is- drill your original rails to make the Si seat bolt to them...using the Si frame rails is helpless..
After that, I then bolted 3 of the 4 bolts in, and noticed one was off. I forced it to bolt in....and the bolt ended up breaking off into the hole. I tried using an ease-out...and no luck. I ended up simply drilling and tapping a new hole for that last hole on the frame..it was only about 1-2" off. After that, they bolted in fine. This took me a LONG time, because I had not read anything on Si seats in a DX or HF before..learned as I went.
Old Oct 10, 2003 | 04:44 AM
Targa250R's Avatar
be professional
Default Re: (Mrock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrock &raquo;</TD></TR><TR><TD CLASS="quote">This took me a LONG time, because I had not read anything on Si seats in a DX or HF before..learned as I went.
CRX DX seats are the same seats as in the CRX Si. Did you buy Civic Si seats?
Old Oct 10, 2003 | 07:23 AM
virginia_dude's Avatar
You can make seats (Frant and rear) from a 95 hatch fit, if you are good at fabrication, I hace '95 Cx hatch seats in mine Front and rear and everything bolts up to stock pan holes. But modifications were made to do that.
Old Oct 10, 2003 | 07:43 AM
driftin4's Avatar
88-89 have totally different attachment points then the 90-91.
The seat bottom in the 88-89 has a bracket that is built into the seat bottom that the 90-91 dont have.
My 90 Si seats would not fit in my 88 without modification to the seat bottom and re-drilling some spots in the bottom.
I have picked up a set of Del Sol seats and will do a step by step on what it takes to make them fit in my 88.
I prefer the Sparco seats in the Rally Car but dont need the invitation of a break-in in the trailer park car...
Old Oct 10, 2003 | 07:55 AM
SamuelK's Avatar
Default Re: civic seat question (driftin4)
so what seats do u guys recommend??
Old Oct 10, 2003 | 08:40 AM
91civicDXdude's Avatar
I have 90 INtegra LS seats in my 91 DX hatch.
Old Oct 10, 2003 | 08:44 AM
SuperJay's Avatar
Default Re: (91civicDXdude)
I have 91 civic si seats in my 89 dx hatch. no mods. no cutting no drilling. straight bolt in affair (for me anyways)
Old Oct 10, 2003 | 09:10 AM
driftin4's Avatar
Default Re: (SuperJay)
Not sure how, but I'm not gonna call you a liar either..
The 90-91 have the seat belt's in the door, this means the receiver end of the belt is attached to the center side of the seat. For Honda to be able to make this work, they had to reinforce the seat attachment points (those of us with 88-89 civics can attest to the fact that the factory attachment points on the bottom of the seat is really weak). When they did this reinforcement they changed the brackets that are built into the floor pan and the brackets that are built into the bottom of the seat. Both are in a totally different position then the 88-89 cars.
Old Oct 10, 2003 | 09:13 AM
4potnick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">I have 90 INtegra LS seats in my 91 DX hatch.
</TD></TR></TABLE>What are you using for the rear seats? Anyone have rear seats other than 88-91 civic that are a good fit? pics?
Old Oct 10, 2003 | 09:57 AM
SamuelK's Avatar
what modifications did u have to make to swap in the LS seats, and did they come in black?
Old Oct 10, 2003 | 11:36 AM
xsellxoutx's Avatar
dude put the seats in the car where you want them, mark the bolt holes, drill holes, then grade8 bolts/washers.
thats how my 91SIseats are in my 88hatch and my friends WRX seat are in his 90hatch
Old Oct 10, 2003 | 11:45 AM
Mrock's Avatar
Default Re: (Targa250R)
I missed where I said I had CRX Si seats...but regardless, here is a picture to add to this post.
http://www.angelfire.com/vt2/l...l.jpg
1988crxdx
Jun 3, 2009 12:51 PM
EF_GUY
May 2, 2008 06:53 AM
cpuff
Oct 24, 2006 08:27 PM
b16_madman
18
Dec 5, 2004 02:57 PM
serious
Mar 27, 2003 07:02 AM
