how did you tie up the engine for your engine pull? *pics*
Old Oct 7, 2003 | 07:16 AM
mykem's Avatar
Default how did you tie up the engine for your engine pull? *pics*
hey guys, i'm all ready for the pull, what did you do, did you just wrap a bunch of chains around it, or did you attach chains to the engine with bolts? what balances it the best for easy pull?
any advice appreciated...thanks!
Old Oct 7, 2003 | 07:37 AM
drjondurst's Avatar
doesnt look like u have a chain, goto autozone and borrow one (it costs a couple bucks, but they give u back ur money when u return it). Then attatch one side of the chain onto a bolt somewhere around the tranny/dizzy that looks sturdy and safe (i cant remember exactly which bolt it is thats recommended in the Helms) then attatch the other side of the chain to another bolt over by the cam/intake mani. again find a bolt that looks safe and pretty strong. You'll need to have the chain angled so you can lift the motor out angled with the motor higher than the tranny. Its alot easier to explain with pics but Im at school.. hope that helps.
Old Oct 7, 2003 | 07:40 AM
slowpokesi's Avatar
Default Re: (drjondurst)
This is how i did it,
because of the ac lines you need to hoist it first, then lower the engine and push the tranny side down to clear the lines and then pull up.
check my sig for a good swap guide and manuals
Old Oct 7, 2003 | 07:41 AM
-slow ej-'s Avatar
chains work best with the cherry picker...i did it the ghetto way...jack it up HELLA high....and den put a skateboard on the bottom and roll out the motor...has just enough clearence for it to get out hahaha =p ( just thought i like to share my idea )
Old Oct 7, 2003 | 07:44 AM
drjondurst's Avatar
the 2nd pic slowpoke posted is the one I used when takin out my motor
Old Oct 7, 2003 | 07:51 AM
1st-hybrid's Avatar
Default Re: (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">This is how i did it,
check my sig for a good swap guide and manuals</TD></TR></TABLE>
Thats the way I did it too. Also add just a bit of "english" and some swearing and you should be good.
Old Oct 7, 2003 | 08:14 AM
drjondurst's Avatar
Default Re: (1st-hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1st-hybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Also add just a bit of "english" and some swearing and you should be good.</TD></TR></TABLE>
haha that definately worked for me
Old Oct 7, 2003 | 08:23 AM
91civicDXdude's Avatar
I've found that a tow strap works great for pulling honda engines. it is soft enough not to scratch and break small parts, but strong enough to hold a b18a1. It will make short work of that puny d series
Old Oct 7, 2003 | 08:24 AM
mykem's Avatar
thanks, that helps me out a lot, hopefully i'll get it out after work tonite...although i have to remove the tranny first before pulling, because i couldn't get the stupid pin out holding the shift linkage to the tranny
Old Oct 7, 2003 | 08:30 AM
slowpokesi's Avatar
Default Re: (mykem)
dude you dont want to do that, just keep at that pin, it will come out, are you using a punch?
what swap are you putting in?
Old Oct 7, 2003 | 08:59 AM
xci_ed6's Avatar
Putting it in from the bottom is easy, you can jack the car high enough to clear w/ just a jack, then lower the car and use the hoist to lift the engine into place.
I did it w/ just jacks (one little hydro, one big hydro) some wood, and a couple jackstands in 2hrs er so.
-Dustin
Old Oct 7, 2003 | 09:28 AM
turbo sol's Avatar
Default Re: (krustindumm)
here is how i did mine
Old Oct 7, 2003 | 09:48 AM
mykem's Avatar
i pounded on that pin forever with a punch and it would not move at all, i got a 98 d16y7 for free, so i'm putting that in there to have a nice new motor, since the d15 is not in the best condition, no $$ for another b16, and the one in my 00 Si is stayin there
Old Oct 7, 2003 | 09:54 AM
slowpokesi's Avatar
Default Re: (mykem)
well since u got to take the tranny off anyway i guess its not that big of a deal.
you could always drop the linkage from the shifter end, and try to pull the motor out with the linkage attached. then when you get the motor out a bit you can try to knock the pin out from above.
Old Oct 7, 2003 | 12:51 PM
McDade's Avatar
homedepot rope!
Old Oct 7, 2003 | 03:16 PM
Starbucks_91b16acrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst &raquo;</TD></TR><TR><TD CLASS="quote">the 2nd pic slowpoke posted is the one I used when takin out my motor</TD></TR></TABLE>
ditto.. all my friends do it that way
Old Oct 7, 2003 | 04:12 PM
CimorelliCRX's Avatar
Default Re: (91b16aCRX)
All i have ever used is ROPE, and I have done around 10 swaps...
Old Oct 7, 2003 | 04:18 PM
Hondasaurs's Avatar
Default Re: how did you tie up the engine for your engine pull? *pics* (mykem)
Saying Goodby to the "ZC"
Old Oct 7, 2003 | 06:04 PM
John O's Avatar
Default Re: how did you tie up the engine for your engine pull? *pics* (Hondasaurs)
Here's my B16a making itself at home.
Prof007
15
Feb 12, 2009 07:12 AM
aznguy0087
Jul 5, 2007 11:22 AM
goodnacl
Jan 16, 2007 05:42 PM
petty$rep
11
Oct 5, 2006 07:07 PM
jbell
Jan 6, 2005 10:55 AM
