cannot separate engine from tranny TRIED EVERYTHING
Hey guys,
I am removing my transmission and cannot separate the MANUAL transmission from the D16Z6 engine.
I have tried a BFH, there is not even a slight gap so it is impossible to use a pry bar, have tried wiggling it and twisting it and shaking it. NOTHING WORKS.
I am using an engine hoist and a jack to remove the tranny.
Please help
Thanks,
AND YES, I HAVE REMOVED EVERY SINGLE BOLT
which include 6 bolt connecting the engine to the transmission
Please help
Thanks,
Re: (coreyhayman)
yes
i am sure i have removed all of the bolts, but i will go check again just to be sure (ive already checked several times, but the engine will still not budge)
Re: cannot separate engine from tranny TRIED EVERYTHING (petty$rep)
I would double check to make sure all of the bolt are out. Other than that, they can be a real PITA to get out, and to just keep trying. Good luck
-Shane
-Shane
Re: cannot separate engine from tranny TRIED EVERYTHING (nighttrain33)
what would you suggest doing besides what ive already done
ALSO I HAVE TAKEN THE STARTER MOTOR COMPLETLY OFF, IS THERE ANOTHER BOLT AROUND THAT AREA
You got all of the bolts. There are only 6 engine-to-trans bolts, so now you just need to keep prying on it.
-Shane
-Shane
K THANKS ill keep tryin but its reallys startin to **** me off, any other suggestions besides prying
THANKS
THANKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petty$rep »</TD></TR><TR><TD CLASS="quote">K THANKS ill keep tryin but its reallys startin to **** me off, any other suggestions besides prying
THANKS</TD></TR></TABLE>
nope prying going to be the only way to get it off. it shouldn't be that difficult. try a fork, and see if that helps any. good luck.
me and my POPS got it off, once we got it to budge it just slide right off LOL
THANKS TO EVERYONE
THANKS TO EVERYONE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petty$rep »</TD></TR><TR><TD CLASS="quote">oh we already took care of that to, except one wasn't enough </TD></TR></TABLE>
So maybe this was the problem.
-Shane
-Shane
AshlandSi
10-15-2001 06:55 PM
