Pop Sound
Old Oct 7, 2003 | 05:51 AM
Kevin Cliff's Avatar
Default Pop Sound
Import leaders,
My hatch is acting up a little. Everytime i take my foot off the accelerator and then start to accelerate I hear a Pop sound. The car seems to be backfiring.
I've heard this is because of my Distributor not being centered. I adjusted it but it still happens (not as much as it used to but its still happening)
Let me know what you think,
Thanks
Old Oct 7, 2003 | 06:11 AM
wickedEFguy's Avatar
Default Re: Pop Sound (Kevin Cliff)
what is your timing set to? also are you throwing any codes?
Old Oct 7, 2003 | 06:18 AM
Default Re: Pop Sound (Ninja_Jc7)
I do have a check engine light
but thats because I'm missing the oxgen sensor
How should the timing be?
Old Oct 7, 2003 | 03:51 PM
dretz13's Avatar
Is it only throwing one code? The ECU will store them in succesion IE: If your throwing code 45, make sure the MIL indictor does the same sequence back to back. If not, write down all of your codes. I've seen a 71, 72, 73 and 74 (random misfire) hide behind the 45 ( too rich / too lean) Is the pop sound coming through the IM? If so, it could be a lean situation. Backfire, too rich, popping, too lean.. By the way, why would you drive around with the CEL on. If its a factory ECU, that puts it in safety mode.
jesiaczek
Jan 26, 2012 03:31 PM
rvd6669
Sep 22, 2009 06:27 AM
jbiel
11
Jan 11, 2009 06:27 AM
onelowchef
Mar 25, 2004 05:58 PM
GSRdriver
Dec 25, 2001 12:48 AM
