***** Are Accord injectors same as Prelude 290cc ?
Old Oct 7, 2003 | 04:22 AM
Charlie Moua's Avatar
Default ***** Are Accord injectors same as Prelude 290cc ?
just wanted to know if I they are the same.... also anyone know if F22 injectors clip right on to Bseires?
Old Oct 7, 2003 | 04:32 AM
KTeller8's Avatar
Default Re: ***** Are Accord injectors same as Prelude 290cc ? (Charlie Moua)
thought lude were like 310
thought they were more then the accord
who in the world wants accord injectors? lol
Old Oct 7, 2003 | 04:36 AM
Default Re: ***** Are Accord injectors same as Prelude 290cc ? (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">thought lude were like 310
who in the world wants accord injectors? lol</TD></TR></TABLE>
well i need to find some 290 or 310cc injectors fairly quick.
I was asking if accord injectors were the same since many f & h series parts are interchangeable.
Old Oct 7, 2003 | 04:42 AM
iakona's Avatar
OBDII prelude injectors are 290cc saturated
OBDII accord injectors are smaller, but i do not know the size.
Old Oct 7, 2003 | 04:52 AM
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">OBDII prelude injectors are 290cc saturated
OBDII accord injectors are smaller, but i do not know the size.</TD></TR></TABLE>
thank you.
do you know if OBD2 h22 injectors clip up to OBD2 harness?
Old Oct 7, 2003 | 04:54 AM
iakona's Avatar
Default Re: (Charlie Moua)
you're welcome.
as far as the Accord harness with the Prelude injectors, i believe so. honda was good about making things in mass quantities the same. but i would test fit one first.
Old Oct 7, 2003 | 04:59 AM
v4lu3s's Avatar
RTFM
stock accord is 235cc or 240cc and the obd1 prelude injectors are 345cc while obd2 are 290cc as measured at 100% duty cycle.
Old Oct 7, 2003 | 08:36 AM
boonacka's Avatar
Default Re: (v4lu3s)
will OBD2 injectors fit OBD1 harness and vice versa?
Old Oct 7, 2003 | 11:54 AM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">stock accord is 235cc or 240cc and the obd1 prelude injectors are 345cc while obd2 are 290cc as measured at 100% duty cycle.</TD></TR></TABLE>
this is correct
Old Oct 7, 2003 | 11:55 AM
paulzy's Avatar
Default Re: (boonacka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">will OBD2 injectors fit OBD1 harness and vice versa?</TD></TR></TABLE>
yes, with a little modding of the clips on teh injectors
Old Oct 7, 2003 | 12:03 PM
DIYaccord's Avatar
Default Re: (Paul_Vang)
will installing prelude injectors into an obd1 accord increase performance at all
Old Oct 7, 2003 | 12:44 PM
v4lu3s's Avatar
RTFM
changing injector size is nto going to do anything except worsen emissions, and robably harm driavability if the ecu is not retuned, unless you are makign substantially more power than stock with a turbo or serious NA buildup.
Old Oct 8, 2003 | 05:43 AM
iakona's Avatar
agreed. too much fuel being dumped in without the ECU base map and fuel injector duty cycle being adjusted = BAD. burned ring landings, etc...
Old Oct 8, 2003 | 06:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">agreed. too much fuel being dumped in without the ECU base map and fuel injector duty cycle being adjusted = BAD. burned ring landings, etc...</TD></TR></TABLE>
you would not burn your ringlands... to do that you would have to be boosted and seriousely over flooding the motor. What normally happens when you have way too much fuel and not enough air in the mixture is that too much fuel can actually wash away some of the oil barrier on your walls and therefor reducing lubercation and cause more wear on your pistons & mainly rings.
better to run rich than lean. 4-5psi over stock would be ok, you'll just notice the car feels slower in the lower RPM and you'll see your MPG drop
Old Oct 8, 2003 | 08:00 AM
iakona's Avatar
you're right charlie. sorry. bad info on my part.
but isn't long term high fuel pressure bad for your combustion chamber? not to mention your O2 sensor(s).
Old Jan 6, 2004 | 12:35 PM
abeaujuin's Avatar
I am losing power in first it feels as if fuel isn't being feed when I step on the gas. Could my injectors be bad?
NathanMorris
Sep 14, 2008 11:06 PM
Hwj_33
Aug 1, 2006 09:03 AM
