SIR II B16a OBD1 with YS1 Cable Tranny FS. CA.
Old Oct 6, 2003 | 10:15 PM
bossman032's Avatar
Default SIR II B16a OBD1 with YS1 Cable Tranny FS. CA.
Hello ALL,
I am selling my JDM MOTOR comes with a YS1 XSi tranny 92-93 Very Good Tranny Slight Grind like All YS1 tranny 3rd Gear. Motor is very strong doing 144HP WHP just with Cheapo Muffler Tech Exhaust cost $270. Oil Changed 3 Times Motor is very strong does not burn Oil or anything car runs like a stock car expect true sleeper I smack Mustangs 5.0 Modded 94-95GSR all the time. Car is stock height to keep cops away. I didnÂ’t race this motor has not been to the track or anything expect mid to low 14s with header intake bolt on. Motor does not smoke or burn fuel. Gives very good gas mileage!!! I went from sac to modesto on 91fuel with only 10bucks little over half tank went and came back. You won’t be disappointed with the purchase. I suggest you change the timing, water pump and you will be set for years.
$2050.
But you will need the following to get the motor running: Vtec Senoild, Clutch, Shift linkage, Dizzy.
Old Oct 6, 2003 | 10:20 PM
bossman032's Avatar
Default Re: SIR II B16a OBD1 with YS1 Cable Tranny FS. CA. (bossman032)
I have put about Under 5k miles no it. I suggest you come check out the motor and drive feel the vtec. Its a very clean running motor. I would let you test drive it if you are buying it or interested. I am selling the swap because I have a CTR swap in that same car.
FYI: for that price I will include the HCP EF motor mounts as a bonus.
Old Oct 6, 2003 | 10:45 PM
bossman032's Avatar
bumps nisstars.
I have pictures
Old Oct 7, 2003 | 06:48 PM
bossman032's Avatar
BUMP!!!
DC5 Demon
Mar 17, 2006 10:08 AM
da_rimrocka3
12
Nov 13, 2005 07:35 PM
Deetz
Sep 25, 2003 10:29 AM
Origin
11
Sep 7, 2003 12:55 AM
bossman032
Sep 5, 2003 10:15 PM
