What camber kit is best.....
Old Oct 6, 2003 | 10:14 PM
brusso's Avatar
Default What camber kit is best.....
I have the 98 spec N1 coilovers and just put on a set of new nitto 555r's. my camber is way off along with the toe and befor i destroy these tires i was thinking about a camber kit .... let me know what you think is best....
Old Oct 6, 2003 | 10:18 PM
sackdz's Avatar
Default Re: What camber kit is best..... (brusso)
The best thing would be to get your toe aligned. As long as you didint completely dump the car the camber should be fine for the street and your tires wont hate you.
Old Oct 7, 2003 | 06:49 AM
typer_801's Avatar
Default Re: What camber kit is best..... (sackdz)
Best rear camber kit = Washers from Lowe's between upper control arm mount and chassis We'll it's probably not the best, but it's the cheapest.
Old Oct 7, 2003 | 08:14 PM
brusso's Avatar
Default Re: What camber kit is best..... (typer_801)
i need more info.....
Old Oct 7, 2003 | 08:31 PM
Black R's Avatar
25 Year Member
.....spc seemed to have some decent stuff in their booth at nopi.
Maybe SRR has released their stuff now?
Old Oct 7, 2003 | 08:44 PM
yeer's Avatar
Default Re: What camber kit is best..... (Black R)
im running skunk2 front camber and ingalls rear. dont know if its the best, but it gets the job done
Old Oct 7, 2003 | 11:32 PM
HYREV2NR's Avatar
I'm running Skunk 2 in the front & OBX in the rear. With both kits I get alot of range of adjustment & I'm very satisfied with both since I'm dropped about 2". Good luck!
Old Oct 8, 2003 | 06:06 AM
Willard's Avatar
Default Re: What camber kit is best..... (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">How long have you Skunk2 and SPC folks been running those kits?</TD></TR></TABLE>
Next season I will be 'testing' my set.
I will be using modified Skunk2 fronts and SPC rears.
Will
-who is at stock ride height... and can't stand washers
Old Oct 8, 2003 | 06:43 AM
Edwin's Avatar
Skunk2 front camber arms, SRR rear toe and rear camber adjusters.
Old Oct 8, 2003 | 07:18 AM
lanceh's Avatar
25 Year Member
Default Re: What camber kit is best..... (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
Will
-who is at stock ride height... and can't stand washers</TD></TR></TABLE>
will - please explain the "modified" skunk2's
Old Oct 8, 2003 | 07:21 AM
MattD@Stoptech's Avatar
Default Re: What camber kit is best..... (lanceh)
My guess = Powdercoating stripped, star washers + stronger bolts used?
Old Oct 8, 2003 | 07:36 AM
Willard's Avatar
Default Re: What camber kit is best..... (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Powdercoating stripped, star washers + stronger bolts used?</TD></TR></TABLE>those and other 'things'
tankz to P1 for some ideas.
Old Oct 8, 2003 | 08:02 AM
Johnny Tran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">tankz to P1 for some ideas. </TD></TR></TABLE>
whahhh?
Old Oct 8, 2003 | 01:38 PM
brusso's Avatar
I just put on a new set of 555r's up front..... with my old tires, i didn't have a problem with the car pulling to the left.... if the old tires didn't pull why are the new ones.... any ideas .... hit me up
Old Oct 8, 2003 | 02:10 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brusso &raquo;</TD></TR><TR><TD CLASS="quote">I just put on a new set of 555r's up front..... with my old tires, i didn't have a problem with the car pulling to the left.... if the old tires didn't pull why are the new ones.... any ideas .... hit me up
tire pressure? alignment?
godluvstegs
28
Mar 18, 2010 11:54 AM
Twincam Sol
Jul 17, 2006 09:32 PM
Crazu.Kanjo.Nick
Suspension & Brakes
Dec 13, 2005 02:21 PM
DV98CVC
Dec 2, 2002 07:44 PM
