How does the AEM air bypass valve works????
Old Oct 6, 2003 | 09:55 PM
Engn's Avatar
Default How does the AEM air bypass valve works????
So how does it works?? Could sombody please tell me!!
Thanks in advance
Kevin
Old Oct 7, 2003 | 05:02 AM
advanracing62's Avatar
Default Re: How does the AEM air bypass valve works???? (Engn)
basically, it's just a small valve that let's air in when the suction is blocked off. So a plastic ring, with foam backed rubber, that is placed in the path of the air flow. When the pressure outside the valve is higer than the pressure inside the valve opens and let's air in, "saving" your motor.
APAem1
Jul 4, 2010 05:18 PM
JDM_SOHC
Mar 28, 2009 01:58 PM
