Where is the coolant air bleed bolt on a B18B?
Old Aug 28, 2001 | 08:02 PM
Pat's Avatar
Pat
Default Where is the coolant air bleed bolt on a B18B?
I have diagrams that only show where it is on the B18C. Supposedly it should be near the thermostat, which looks like is on the lower rad. hose for the b18b, but I couldn't find it anyways. And its so crowded in there with all sorts of hoses, it would be hard to get a socket in! On the B18C the thermostat is by the upper rad hose I think? Thanks for any help!!
Old Aug 28, 2001 | 09:02 PM
Tigger's Avatar
Default Re: Where is the coolant air bleed bolt on a B18B? (Pat)
There isn't a bleed valve on the B18B. The manual says to run the engine for a while (until the fan comes on twice), then shut off the engine. Wait for it to cool down a bit, then take off the radiator cap (make sure its cooled, don't want to get scalded). Then add more coolant as needed.
Old Aug 28, 2001 | 10:22 PM
bigTom's Avatar
on the b18c its a little nipple somewhere on the left-front side of the motor... looks like the bleeder valve on the brake calipers... its somewhere there... i just cant really describe it now... (and im really tired) and i cant find a good pic!
Old Aug 28, 2001 | 10:51 PM
Rain_man's Avatar
New User
Default Re: Where is the coolant air bleed bolt on a B18B? (ek9t)
I have a b18b and it's on the front of the block, to the left of the valve cover, just below the distributor.
Old Aug 29, 2001 | 04:33 AM
Ubermensch's Avatar
Default Re: Where is the coolant air bleed bolt on a B18B? (Ein)
Ein, I could have sworn I looked there and didn't find it. I assumed the b18b didn't have it. I'll look again...Generally I don't have and problem with removing air formt he system by just running the engine and getting things hot, then I squeeze the upper and lower radiator hose to get the air out.
Old Aug 29, 2001 | 09:36 AM
90integraGS's Avatar
New User
Default Re: Where is the coolant air bleed bolt on a B18B? (Ubermensch)
I don't know about the B, but the B18A has a bleeder valve just to the right of where the upper radiator hose connects to the engine. It's really easy to get to with a socket wrench.
[Modified by 90integraGS, 6:08 PM 8/30/2001]
Old Aug 29, 2001 | 10:23 AM
Rain_man's Avatar
New User
Yep, 90IntegLS hit it right on the head, just use a 12mm box wrench. Be sure to tighten it well cause it's somewhat prone to leaking.
Old Aug 29, 2001 | 10:46 AM
Pat's Avatar
Pat
hmmm I coulda sworn I looked in that area and there was none on mine (a 98). Anyone have an close-up picture of their engine bay?
Old Aug 30, 2001 | 03:07 PM
New User
I hope this is clear:
Old Aug 30, 2001 | 04:58 PM
non-VTEC's Avatar
i think some or all the 94+ B18B engine's dont have the bleeder screw. mine doesn't have one either......
Old Aug 30, 2001 | 07:55 PM
Pat's Avatar
Pat
Default Re: Where is the coolant air bleed bolt on a B18B? (non-VTEC)
yeah that screw is not on my hose area based on the picture. I wonder why honda took it out??
oh yeah thanks for the pic 90integraGS
[Modified by Pat, 9:08 PM 8/30/2001]
Old Aug 30, 2001 | 10:03 PM
Rain_man's Avatar
New User
My guess is that because in all the time I've used that bolt, air has NEVER come out of it. I would say I've done about 5-6 coolant changes so far too... not all of them scheduled unfortuantely...
Old Aug 31, 2001 | 03:46 AM
New User
Hey, do you think that's where the extra 10 hp comes from??
Old Sep 1, 2001 | 04:27 PM
bigTom's Avatar
Default Re: Where is the coolant air bleed bolt on a B18B? (90integraGS)
here's another pic i finnally found... u can see where the screw is relative to the other picture
Old Sep 1, 2001 | 04:30 PM
bigTom's Avatar
u can see it right next to the end of the manifold in the picture
Old Sep 1, 2001 | 04:34 PM
non-VTEC's Avatar
that's not a B18B.........none the less a very interesting picture........where are the rest? i'd like to see mone engine bay shot and a list of mods on that baby!!
Old Sep 1, 2001 | 04:37 PM
bigTom's Avatar
true... its not a ls but u can see where the bleeder bot is... i dont know if i can release the specs on the motor... over 600 hp and it was a street car
Old Sep 1, 2001 | 04:45 PM
non-VTEC's Avatar
95 B18B1:
as for that B18C1.........looks like a beast!! over 600hp is still probably one of the most powerful b-series engines out today.......cool!
Old Sep 1, 2001 | 06:44 PM
Pat's Avatar
Pat
non-VTEC, that hole to the right of the upper rad hose, isn't that where you would have the bleeder screw. I don't have that nubby thing on mine
Old Sep 1, 2001 | 07:08 PM
non-VTEC's Avatar
well that's where i would assume the bleeder screw would be buy mine doesnt have one..........my brother's 92 civic has one in that location......so who knows what honda is thinking!
Old Sep 1, 2001 | 09:06 PM
Pat's Avatar
Pat
is the hole plugged up ?
Old Sep 1, 2001 | 10:53 PM
RacingE_Teg's Avatar
I don't have a bleeder screw there either. And the hole is plugged up on mine.
Old Sep 1, 2001 | 11:00 PM
96IntegraLS4DR's Avatar
Default Re: Where is the coolant air bleed bolt on a B18B? (RacingE_Teg)
Mine's plugged up also. This is B18B or 96 Teg LS SE
lsturbo*
Nov 27, 2008 10:52 AM
IGODWN
Jun 30, 2008 10:29 PM
DA is best
Sep 11, 2006 09:50 AM
Honda_Accord
Aug 31, 2006 08:25 PM
