Question about block with after market cams?
Old Oct 6, 2003 | 07:35 PM
redrex's Avatar
Default Question about block with after market cams?
OK so im lookin to get the exospeed stage 2 cams and some head work done and prolly a rechipped ecu....my motor has 180k on it and i was wonderin should/do i need to do anythin to the block...I wanna run a 50/75 wet shot also. The motor runs good now, doesnt burn oil or anythin but can the rods handle the higher revs?
Btw this is on a d16a6
Old Oct 7, 2003 | 12:12 AM
91civicDXdude's Avatar
a d16a6 has one cam, not cams.
by the sound of it, you should maybe look into a quick hone/rering of the engine. even though it doesnt smoke or anything, 180k is a lot on an old engine like the a6, and reringing shouldn't cost that much, since you say it doesnt smoke you probaly wont have to bore it out.
B20PWRD
Feb 8, 2009 06:05 PM
richboi
Nov 9, 2008 02:19 PM
0c00l
Jan 3, 2008 11:43 AM
b18chatchg
Jun 18, 2006 05:50 PM
Used2beAb16
May 4, 2004 04:29 PM
