Clutch install Question
If you look in the middle of your flywheel, there is a little bearing in it. This bearing replaces that one. Simply bang it out and pop in the new one
Make sure that when you re install the new bearing, you don't hit it in the "darker" area.
That could damage it severely, tap it in using a socket that is the same size as the bearing, and use the backside of the socket, not the opening side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muse »</TD></TR><TR><TD CLASS="quote">Make sure that when you re install the new bearing, you don't hit it in the "darker" area.
That could damage it severely, tap it in using a socket that is the same size as the bearing, and use the backside of the socket, not the opening side.</TD></TR></TABLE>
u don't ahve to remove the flywheel!
just get a bearing remover...
all the flywheels and clutch's that i have worked on u never have to remove the flywheel...
and i've pulled clutchs on hondas/domestics.. etc. etc....
it' will save u time and labor.. just get a bearning puller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost »</TD></TR><TR><TD CLASS="quote">u don't ahve to remove the flywheel!
it' will save u time and labor.. just get a bearning puller</TD></TR></TABLE>
wrong you do have to take off the flywheel
the bearing comes out from the backside of the flywheel....and must be installed the same way....it won't come out without taking the flywheel off....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">
the bearing comes out from the backside of the flywheel....and must be installed the same way....it won't come out without taking the flywheel off....</TD></TR></TABLE>
Yup, and that is a pilot bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noble4ws »</TD></TR><TR><TD CLASS="quote">did the h23 have one also because thats where the flywheel came from</TD></TR></TABLE>
No.
No.
just double checking the h23 flywheel DOES NOT have a pilot bearing, so then is it ok to use the h23 flywheel on the h22, thanks for the info guys its the only thing keeping me from getting this engine together and in
did you get a clutch for a h22 or h23? If you can put the pilot bearing in place of the bushing and it all fits, do it. Try to put the bearing on the input shaft of the trans first to see if it fits.
We did try and see if the pilot bearing would fit on the input shaft but it didnt should we just keep the bushing?
god damn this post has been goin for way too long....
thanks guys
thanks guys
