Race only engine, plug question
So I am going from a static compression ratio of 8.5:1 to 11.5:1, the stock NGK is a BPR6ES, the next heat range cooler is a BPR7ES but I cannot find these available readily. I can get the BPR8ES this plug is two stages cooler, would this plug be too cold? This engine will only be seeing high rpm race use. NO street use at all.
-Joel
-Joel
cehcivic15
Aug 3, 2010 01:23 AM
rewerbcrx
May 11, 2006 06:12 PM
