Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Race only engine, plug question
Old Oct 6, 2003 | 07:01 PM
B17CR-X's Avatar
Default Race only engine, plug question
So I am going from a static compression ratio of 8.5:1 to 11.5:1, the stock NGK is a BPR6ES, the next heat range cooler is a BPR7ES but I cannot find these available readily. I can get the BPR8ES this plug is two stages cooler, would this plug be too cold? This engine will only be seeing high rpm race use. NO street use at all.
-Joel
Old Oct 7, 2003 | 04:19 AM
metalworker's Avatar
Default Re: Race only engine, plug question (B17CR-X)
Try the 8. My guess is that you would want to go at least that cold. I would recommend maybe even trying a 9. Run the 8 and check for detonation.
hussain-vtec
Jan 18, 2021 01:53 AM
cehcivic15
Aug 3, 2010 01:23 AM
alex_s817
Mar 7, 2007 03:49 PM
rewerbcrx
May 11, 2006 06:12 PM
AsianMullet
Nov 8, 2003 10:46 PM
