edelbrock intake manifold dyno comparison vs Type R stock manifold
Old Oct 6, 2003 | 07:00 PM
shant's Avatar
Default edelbrock intake manifold dyno comparison vs Type R stock manifold
green and red are type R manifold blue is edelbrock manifold
time slip comparison
left slip is with green dyno run, right slip is blue dyno run
last time out i hade the red dyno run and i broke my clutch, i should have left it alone.
Old Oct 6, 2003 | 07:03 PM
kungfuSiR's Avatar
holy crap that's a huge loss in power, what did you use to tune the car with the new manifold?
Old Oct 6, 2003 | 07:07 PM
shant's Avatar
Default Re: (kungfuSiR)
i tune the car with a apex safc both times.
Old Oct 6, 2003 | 07:13 PM
MAX_CFM's Avatar
Default Re: (shant)
What comp ratio? is the engine
we have had really good luck with the JG mani
Old Oct 6, 2003 | 07:15 PM
shant's Avatar
Default Re: (MAX_CFM)
its a ls crank with pr3 pistons, type R head, i think the compression is around 11.3 as per c-speedracing compression calculator, but im not sure.
Old Oct 6, 2003 | 07:22 PM
MAX_CFM's Avatar
Default Re: (shant)
That would be your problem
need about 12.5 with tht mani
Our engine still makes power@ 10k still going up with that mani
How much does yur car weigh fast car for stock parts
Drag R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">What comp ratio? is the engine
we have had really good luck with the JG mani</TD></TR></TABLE>
he's definatly not spinning the motor like you do, Brad
Old Oct 6, 2003 | 07:29 PM
shant's Avatar
i dont know what it weighs, unfortunatly i havent been able to make it to the scales in the past two events, first clutch, now oil pump.
its not a street car, its dedicated race car and im guessing the weight is around 1800lb with me.
Old Oct 6, 2003 | 07:36 PM
GokuSSJ4's Avatar
Default Re: (shant)
what cams are you running ??
im still debating if to stay with the ITR or go with the JG
Old Oct 6, 2003 | 07:58 PM
SpdFrk's Avatar
Is that the blue all motor Si u posted a vid of?
Old Oct 6, 2003 | 08:20 PM
JBk24crx's Avatar
Default Re: edelbrock intake manifold dyno comparison vs Type R stock manifold (shant)
that low of compression of course the type r will come on top you need higher comp and higher rev limit. 11.3comp isnt high enough for the JG. run higher compression you will see the difference.
Old Oct 6, 2003 | 08:34 PM
SOHCArchangel's Avatar
Default Re: edelbrock intake manifold dyno comparison vs Type R stock manifold (rub760)
yeah anywhere cr wise of 13-14:1, a good profile cam to make that manifold work, and a good tuning tool
an afc is too blunt of a tuning tool
plenum volume is your freind
Old Oct 6, 2003 | 08:46 PM
shant's Avatar
Default Re: edelbrock intake manifold dyno comparison vs Type R stock manifold (SOHCArchangel)
im going to keep the edelbrock manifold. but for now im going to use the type R, since my motor is not ready to use the edlebrock yet. i guess i need more compression, my 11.3:1 is not enoguh, i also dont have enough cash to do anything about it.
i wonder how those will do once i get the compression up also?
Modified by shant at 12:44 AM 8/7/2004
Old Oct 6, 2003 | 09:28 PM
GokuSSJ4's Avatar
how about 12.8CR and Toda spec D's ??
Old Oct 6, 2003 | 09:49 PM
sgT's Avatar
sgT
Default Re: edelbrock intake manifold dyno comparison vs Type R stock manifold (Spoon1)
My torque went from 165+ to 140 with the JG manifold.
I did gain hp from 9500-10500 but i dont think it was worth the torque loss from 3000-8000.
Ive seen similar results on a couple of other motors as well.
Old Oct 6, 2003 | 11:55 PM
AussieK24's Avatar
Top post, Shant
Old Oct 7, 2003 | 03:50 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: edelbrock intake manifold dyno comparison vs Type R stock manifold (AussieB20vtec)
That Jg manifold is better suited for boost. That has always been the rumor, and now heres your proof.
Old Oct 7, 2003 | 04:05 AM
MAX_CFM's Avatar
Default Re: edelbrock intake manifold dyno comparison vs Type R stock manifold (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">My torque went from 165+ to 140 with the JG manifold.
Yea I guess it all depends what application
we leave @ 8k and the motor doesnt see under 8k but for a split sec
I think a track test should be done on a car with hi compression too
Old Oct 7, 2003 | 11:10 AM
GokuSSJ4's Avatar
Default Re: edelbrock intake manifold dyno comparison vs Type R stock manifold (MAX_CFM)
I think a track test should be done on a car with hi compression too</TD></TR></TABLE>
true , i know some race cars run the IM but is it worth it for a N/A set up for the street . i really seeing that is not . and even for auto cross .. i guess itr it is , not worth it loosing TQ just to gain a bit on the top end
Old Oct 7, 2003 | 11:46 AM
Austin's Avatar
Do you have a plot with the A/F ratios for the runs?
Austin
Old Oct 7, 2003 | 03:25 PM
skunked's Avatar
So have we. We lost power using the stock JG piece at first, then the port tool came out and we gained power over the Skunk2.
Old Oct 7, 2003 | 11:09 PM
jdmcivicferio's Avatar
Default Re: (skunked)
I haven't seen any impressive numbers out of the jg, it seems to lose all it's low end and just make power between 7000-11000 rpm. And make disapointing results. The type r manifold with a mild port I have seen make more respective numbers.
Old Oct 8, 2003 | 12:53 AM
Carlo Gambino's Avatar
whatta huge lost.
Old Nov 7, 2003 | 01:17 PM
GOLDBERG's Avatar
Default Re: (TheSicillian)
up..any dynos with 12.0cr and above with the jg?
Old Nov 7, 2003 | 02:03 PM
2156cc's Avatar
Default Re: (GOLDBERG)
When I went from the jdm itr manifold to the jg manifold I lost hp all over the place. But after 2 hours on the dyno I ended up with about 8 more hp on the big end and about the same tq numbers.
15:1 ls/vtec deckplate motor (RS motorworks)
