spoon Integra-R P73 Piston Set
Old Oct 6, 2003 | 04:43 PM
JBBNJ609's Avatar
Default spoon Integra-R P73 Piston Set
i found spoon Integra-R P73 Piston Set
• OEM JDM Integra-R pistons, balanced by Spoon.
• Complete with rings and wrist pins. for 344 shipped . . brand new , what do you think of all these ??
is it worth the extra bit to go with NEW spoon ones , or should i just get some OEM jdm itr p73-00 pistons and rings ( i need the pistons , rings, wrist pins , new bearings, and rods )
Old Oct 6, 2003 | 05:38 PM
skribblah's Avatar
Default Re: spoon Integra-R P73 Piston Set (jason bouchard)
dont be another spoon *****...
just get the fkin JDM P73's
Old Oct 6, 2003 | 05:41 PM
JBBNJ609's Avatar
Default Re: spoon Integra-R P73 Piston Set (skribblah)
how much for that new with rings and rods and wrist pins, what else do i need for it to work in my b18c1 ??
Old Oct 6, 2003 | 05:42 PM
JBBNJ609's Avatar
ok, 94 gsr , 100k miles on it
DAC intake
stock intake mani( will get a enw one , but dont know what to get )
dc sports 4-2-1 header ( crap, wanna sell and get somthing better , maybe a JDM ITR header)
the full seup you guys are selling ( m22, valve springs , retainers )
a new set of stock valves ( i think a few are screwed up )
chipped ecu to rev to about 9 or so
thinner headgasket ( i dont know which one ) to get my CR to closer up for that M22 cam
a greddy SP exhaust 2.36 ( yes too small, but i got it free , what should i upgrade to?)
everything else is stock, o and i have a set of 110% honda accord injectors , not in the car yet ( i think there 310cc)
+what else should i get and can i run on pump 93or 94 OCTAIN gas ?
o yea , and shoul i upgrade to a better timing belt ( if so , which one ?))
and which cam gears to get ? thanx for taking your time to help me out . . .
Old Oct 6, 2003 | 05:46 PM
notstock93's Avatar
Spoon pistons are literally just bought right from the factory and balanced, then sold at double the price. If your going to get some new pistons, look into buying them yourself and sending them out to be balanced at your local shop. It would be cheaper and give you the same effect. Also, if your going to be installing balanced pistons, get the rest of the bottom end balanced (not much more money) other wise, the piston weight wont matter.
Old Oct 6, 2003 | 05:49 PM
JBBNJ609's Avatar
Default Re: spoon Integra-R P73 Piston Set (notstock93)
well, what else would get balenced and what do they do when its balenced , also what else would i need from what i listed ??? thanx . . jay
Old Oct 7, 2003 | 05:56 AM
skribblah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">ok, 94 gsr , 100k miles on it
DAC intake
*get the skunk 2 manifold
*JDM ITR would be good. or AN-R or SMSP
*sweet
*what makes you think yours are screwed up?
*what kind of chip? might want to consider going hondata
*dont do it. never look for more compression thru the headgasget... its a bad idea.
many people will disagree but i wouldent do it for reliability's sake. knowing you can rev the **** out of the engine and not blow a HG
*thats a good size.
*not sure if that would work... might want to check into getting 97 - 01 prelude VTEC injectors. they are 290cc and new from the dealer all 4 are about 80-90 bucks.
*hondata
*you could get the toda timing belt.. or just stick with oem.
*really they are all the same, just look for ones with 4-5 bolts. DONT get AEM gears, then you have a chance of telling another horror story of how the bolt sliped and you droped a valve. the reason they have a reputation for slipping is b/c of they onlyl use 3 bolts. i dont know how the GEM ones hold up either. id get HKS (saw some in the classifyeds forum), skunk2, or ENDYN. ENDYN's have 5 bolts.
Old Oct 7, 2003 | 07:38 AM
IN VTEC's Avatar
They're not even machined-balanced. They just put together sets of closely weighted pistons so that they're within a gram of each other in mass.
The one set of OEM Honda pistons I've weighed were as much as 3 grams of separation in the set. Pricing is only slightly higher on the Spoon-balanced sets. I got mine for $265 with rings a year ago when IPS had them on special.
Old Oct 7, 2003 | 08:46 AM
JBBNJ609's Avatar
hondata is like 500$ , i dont have the money for that yet . . . i may btt( by the time) XMAS rolls around . . . thats when im doing most of this , and the valves i have lots of ticking , my gas milage is getting shittyer and shittyer . . . it is running like .5 secs slower in the 1/4 now . . . it donesnt feel as fast ( i no ino , butt dynos are bs haha) it sounds like i need a valve adj. really really badly , but all of then are in spec .. idk
Old Oct 7, 2003 | 09:44 AM
gsr-2nr's Avatar
spoon pistons whoop de do dont know how they can improve an already bad *** piston from the factory but if u wanna waste the money go 4 it
Old Oct 7, 2003 | 10:08 AM
P1mpSlap's Avatar
From what I understood it as, Spoon balances all JDM OE pistons. Regardless if they sell them under the spoon name or not. The only thing that matters is how well they are balanced.
Old Oct 7, 2003 | 10:04 PM
notstock93's Avatar
Default Re: (P1mpSlap)
As to your question on what else gets balanced when the whole bottom end is balanced, its the
pistons
crank
rods.
This reduces high RPM harmonics and give youa "smoother" revving engine and adds longevity to boot.
P.S.- my hondata was 280 AFTER tax. Thats less than an S-AFC
Old Oct 8, 2003 | 11:59 PM
JBBNJ609's Avatar
Default Re: (notstock93)
wow 280 ??? then i will be prob getting it after all. . .
Old Oct 9, 2003 | 12:19 AM
Tyteteg119's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">Spoon pistons are literally just bought right from the factory and balanced, then sold at double the price. If your going to get some new pistons, look into buying them yourself and sending them out to be balanced at your local shop. It would be cheaper and give you the same effect. Also, if your going to be installing balanced pistons, get the rest of the bottom end balanced (not much more money) other wise, the piston weight wont matter.</TD></TR></TABLE>
Someone doesn't know what they are talking about. If someone is selling them for Double then they would run about 600 cause a New Set of JDM ITR Pistons run about 330+ Surely not 150
Old Oct 9, 2003 | 09:53 AM
notstock93's Avatar
Default Re: spoon Integra-R P73 Piston Set (Tyteteg119)
I was being sarcastic.
93Civic_hb
Aug 18, 2008 07:08 PM
flashgsr
Oct 28, 2002 07:47 PM
gandhisan
Sep 27, 2002 06:35 AM
AutoXsi2000
Jan 14, 2002 11:16 AM
