Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Superpro bushings - alternative to Mugen
Old Oct 6, 2003 | 03:02 PM
Jason C SBB's Avatar
Default Superpro bushings - alternative to Mugen
Superpro don't make their bushings super-hard like ES.
I will install the 1997 2-door, Front suspension, lower arm, inner, rear bushing. They have a version that increases caster.
(You can get them with standard caster, or increased caster.)
TransMark Sales Company is the US dealer:
transmark@charter.net
616-403-0260
$67.78 for a set.
Old Oct 6, 2003 | 03:22 PM
carl_aka_carlos's Avatar
Default Re: Superpro bushings - alternative to Mugen (Jason C SBB)
how much does it increase caster?
<---could use some more caster so i don't need to run so much static negative camber
Old Oct 6, 2003 | 03:40 PM
Default Re: Superpro bushings - alternative to Mugen (carl_aka_carlos)
Around 1 degree.
Swapping upper control arms left to right supposedly increase by 2 degrees.
Old Oct 7, 2003 | 12:14 PM
SoloSol's Avatar
Pic or site link?
Old Nov 14, 2003 | 06:23 AM
IntEGNYC's Avatar
Default Re: Superpro bushings - alternative to Mugen (SoloSol)
Here's the link http://www.superpro.com.au
Do they make trail arm bushings?
Old Nov 14, 2003 | 11:27 AM
Default Re: Superpro bushings - alternative to Mugen (IntEGNYC)
Yes they do. Here's their 5Mb catalog
http://www.superpro.com.au/docs/superpro.pdf
Old Nov 14, 2003 | 12:43 PM
SPiFF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Trailing Arm Lower - Front Bush SPF0807K 1 Use OE mount pin 30mm OD, 74mm OD bush 2B</TD></TR></TABLE>
Have to reuse the OE metal pin like the ES. I would not do that again after doing the ES install.
Old Nov 14, 2003 | 01:01 PM
Kakkoii Integra's Avatar
New User
cool, they have a rear trailing arm bush for the DA. anyone seen what their RTA bushing look like? are they solid like ES and prothane, or open like OEM and mugen?
jeff
Old Nov 15, 2003 | 03:59 PM
Stubbs's Avatar
For any DA9er that's interested OPM autosports sells a mugen trailing arm bushing. It's a 88-91 civic/crx trailing arm bushing resleeved to fit the 90-93 integra trailing arm. That is if you can get them to send it to you(I've been waiting 5 weeks and they might send them out to me next week).
slim9300
Nov 8, 2006 09:25 PM
importboi22
Suspension & Brakes
11
Feb 28, 2005 12:33 AM
Jon V
44
Jun 23, 2004 02:03 PM
Rain_man
May 1, 2003 09:12 AM
JinMTVT
Jan 25, 2002 07:23 PM
