unusual motor problems...
Old Oct 6, 2003 | 02:21 PM
SimbaDogg's Avatar
Default unusual motor problems...
ok, this morning on my way to skool., i tried starting my car, didn't work. i thought my started cable came loose (this sometimes happens, its not properly secured to the started) but i popped my clutch and drove to skool fine. after getting out, i tried starting my car, nothing. then i tried again, it started and died. i tried again, same result. after doing this a few times i started to get frustrated. then i tried starting the car, and holding the key in the "start" position, this allowed the car to continue running w/out stalling. so i had to drive 10 miles home holding the key in the start position. anyone know what could cause something like this? as of right now...i can't drive anywhere like this
Old Oct 6, 2003 | 02:26 PM
matt_sb2000's Avatar
Default Re: unusual motor problems... (SimbaDogg)
Sounds like a fuel pump wiring problem.
The start position turns the fuel pump relay on as long as it's on the start position.
Check for fuel pressure. Start the car, and have someone watch the fuel pressure gauge.
Old Oct 6, 2003 | 02:28 PM
SimbaDogg's Avatar
Default Re: unusual motor problems... (matt_sb2000)
here's the thing though...the starter wouldn't make the grinding noise @ all when i held it. but when i depressed the clutch, then it would make the "you're an idiot cuz you're trying to start your car when its already on" noise
Old Oct 6, 2003 | 02:29 PM
Yes, because the clutch switch doesn't let the starter come on unless you push the pedal down.
Nothing strange about that.
Old Oct 6, 2003 | 02:50 PM
civickiller's Avatar
main relay
Old Oct 6, 2003 | 02:51 PM
Default Re: unusual motor problems... (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">main relay</TD></TR></TABLE>
How do you check that? / go about finding it?
Old Oct 6, 2003 | 02:53 PM
SimbaDogg's Avatar
how can i check to make sure its not the main relay, that shiets expensive
Old Oct 6, 2003 | 03:14 PM
Bump...
Old Oct 6, 2003 | 03:31 PM
HondaPartsHero's Avatar
Technical Hero
its only 50 bucks or you can resolder it for free. turn the key over to accessory and listen for the fuel pump click and the check engine light will go off. if it doesn't do both of these then it is the main relay. heres how to do it:
http://www.markl.f9.co.uk/howt...y.htm
Old Oct 6, 2003 | 03:35 PM
kyle h.'s Avatar
i dont mean to sound like a dick but. the search function works great. it's been covered in detail many times
Old Oct 6, 2003 | 03:36 PM
SimbaDogg's Avatar
Default Re: unusual motor problems... (kyle h.)
sure...it works great, but i think it doesn't really apply to this situation.
Old Oct 6, 2003 | 03:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yebabee &raquo;</TD></TR><TR><TD CLASS="quote">its only 50 bucks or you can resolder it for free. turn the key over to accessory and listen for the fuel pump click and the check engine light will go off. if it doesn't do both of these then it is the main relay. heres how to do it:
http://www.markl.f9.co.uk/howt...y.htm</TD></TR></TABLE>
Reasonable answer. Thank you for your time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. &raquo;</TD></TR><TR><TD CLASS="quote">i dont mean to sound like a dick but. the search function works great. it's been covered in detail many times</TD></TR></TABLE>
You sound like a dick... Answer the question, or don't post. No need to tell people to search.
Old Oct 6, 2003 | 04:46 PM
91civicEX's Avatar
please tell me you didnt drive 10 minutes with the starter on. if just holding the key in the start position will let your car run like its in the run position then it could be and ignition switch problem.
Old Oct 6, 2003 | 05:24 PM
SimbaDogg's Avatar
Default Re: (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">please tell me you didnt drive 10 minutes with the starter on. if just holding the key in the start position will let your car run like its in the run position then it could be and ignition switch problem.</TD></TR></TABLE>
whats what i'm thinking it is, because when i turn it to the on position, you can hear the fuel pump prime and pressurize the system, but i really think its the ignition system, cuz i can't even pop the clutch and start it. what exactly it could be i dont know.
Old Oct 6, 2003 | 07:05 PM
SimbaDogg's Avatar
Default Re: (SimbaDogg)
ok...i disconnected the fuel return line to see if there was still fuel coming back when the system was primed, and when the motor was running. and sure enough, there's still fuel coming back. so maybe something w/ the ignition system? wiring?
Old Oct 6, 2003 | 07:46 PM
SimbaDogg's Avatar
i'm running out of things to check here guys..any help?
Old Oct 7, 2003 | 12:27 AM
SimbaDogg's Avatar
well...anyways i my friend hieu came over w/ his single cam crx (with the fugged up door )and i tried using his main relay...that didn't work. then i tried hooking up his ecu to my harness...that didn't work either. so ecu and main relay are ruled out
Old Oct 7, 2003 | 02:10 AM
did u check for spark ? thats something easy to do, maybe yoru coil went out or ignitor
devin_hoang
11
Dec 31, 2008 06:01 PM
rice is nice
11
May 2, 2005 11:15 PM
SpoolinEK9
Mar 15, 2005 04:25 PM
vxnine
13
Sep 26, 2004 05:17 PM
Accord15
Jun 25, 2003 09:54 AM
