d16z6 swap question in a 4dr
Old Oct 6, 2003 | 01:32 PM
KOOL-AID's Avatar
Default d16z6 swap question in a 4dr
ok guys i have one question! ok i have the d16z6 in the car and everything and i converted my car to obd1 but my question is on the z6 it has a sensor where the thermostat is like the housing but on the old d15 it has no sensor so im worried about it throwing any codes.....i did search for this but i couldnt find anything about it also i dont have everything put together yet.....i just need to know if it should matter and if it does that way i could wire it up??
Old Oct 6, 2003 | 01:42 PM
civickiller's Avatar
Default Re: d16z6 swap question in a 4dr (KOOL-AID)
i had the same thing on my ls block, but sorry i couldnt find the answer to if its needed or not
Old Oct 6, 2003 | 01:44 PM
KOOL-AID's Avatar
Default Re: d16z6 swap question in a 4dr (civickiller)
so what did u do??
Old Oct 6, 2003 | 04:50 PM
91civicEX's Avatar
the Z6 has some kind of integrated sensor on the thermostat. i think it might be the coolant temperature sensor. did that plug, plug in somewhere? if it didnt theres your answer. if it did then you got a free bump
BUMP FOR THE 4 DOORS
Old Oct 6, 2003 | 05:11 PM
KOOL-AID's Avatar
Default Re: d16z6 swap question in a 4dr (91civicLX)
yea i know it didnt plug anywhere but im using a p28 ecu i should of said that but did u have a plug like that when u did an engine swap??
armstr9989
Mar 20, 2019 02:45 AM
welfarepc
Oct 17, 2007 01:22 AM
rosscaboss
Jul 25, 2007 01:48 PM
gnar kill
Nov 24, 2005 09:24 AM
SPORT INJECTION
Jun 27, 2003 10:48 AM
