How do you drain the PS wrack of a 5th gen? (4th gen was easy, this is not)
Old Oct 6, 2003 | 12:51 PM
Greyout's Avatar
Default How do you drain the PS rack of a 5th gen? (4th gen was easy, this is not)
On my 4th gen, I crawled under the car, undid the main PS line which was clearly visable on the bottom of the rack, and watched as all the PS fluid drizzled out.
On my buddies 5th gen, I suspected that it would be a similar setup. We drained the PS container under the hood, took the pump off, and I crawled under the car to finish the job.
There is not a single PS line visable anywhere. I have no idea how anyone would get to it without pulling the rack.
We turned the wheel left and right, and got some fluid to squirt out the hardline up by the pump, but I'm sure there is still lots left in there. How would we get to it?
PS - driving the car without powersteering is interesting, but not impossible. I'm by no means a big guy, and I did not find it difficult to drive. It feels GREAT above 30 mph. Takes too hands below 30mph though... I'd like to get rid of the rest of the fluid to see how much more it helps.
Modified by Greyout at 10:09 PM 10/6/2003
Old Oct 6, 2003 | 02:03 PM
Greyout's Avatar
Default Re: How do you drain the PS rack of a 5th gen? (Greyout)
surely someone has done this
Old Oct 6, 2003 | 03:56 PM
577HondaPrelude's Avatar
the EZ way is to disconnect the line on the output side of the PS pump, then turn the car on and move the wheel to full left then full right. It will all come right out.
Old Oct 6, 2003 | 04:59 PM
Paul H22A4's Avatar
the pumps already off. Hows autoX'ing without p/s ?
Old Oct 6, 2003 | 05:24 PM
rjr162's Avatar
Default Re: (Paul97)
the lines are above the rack. go to hondaautomotiveparts.com and look at the PS rack for a 97+
Old Oct 6, 2003 | 08:01 PM
slowone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul97 &raquo;</TD></TR><TR><TD CLASS="quote">the pumps already off. Hows autoX'ing without p/s ?</TD></TR></TABLE>i liked autocrossing without ps alot better. slaloms, slow 180s, boxes were all fine to me.
Old Oct 7, 2003 | 01:26 PM
Greyout's Avatar
Default Re: (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">the lines are above the rack. go to hondaautomotiveparts.com and look at the PS rack for a 97+</TD></TR></TABLE>
so is the only way to get to it to take the intake manifold off and attack it from above?
I see a hondata intake manifold gasket in the future....
Old Oct 7, 2003 | 08:06 PM
Default Re: (Greyout)
Or you can drop one end of the rack down from below to get to it. I think I remember reading something about doing that, and it didn't seem to hard. Let us know how you do it, I might be doing the PS removal some time this winter.
z71rider
Aug 30, 2013 11:34 AM
mantle325
Sep 13, 2009 01:45 AM
sleepystyle
Nov 29, 2005 05:40 PM
mjensen
Apr 6, 2004 03:28 PM
