difference between 38mm and 40mm tial wastegate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg »</TD></TR><TR><TD CLASS="quote">do you know how much more flow it has?</TD></TR></TABLE>
...about 2mm's worth. LOL!
But I'm pretty sure the difference is not that big of a deal. (Unless you're running an uber-sized turbo and need to keep the 30+psi of boost in check)
40mm has been discontinued and is being rpelaced with the 44mm. The 44mm is a vband wastegate and without a doubt the sickest gate on the market... but its 3 weeks away
Inline Pro has used a Turbosmart 35mm wastegate in their 9 second race car
So in honesty, you really don't need a 40/44mm wastegate on a street car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe »</TD></TR><TR><TD CLASS="quote">
But I'm pretty sure the difference is not that big of a deal. (Unless you're running an uber-sized turbo and need to keep the 30+psi of boost in check) </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL website »</TD></TR><TR><TD CLASS="quote">Flow capacity. Contrary to popular belief, larger higher HP applications do not necessarily require the largest wastegate available. The lower the boost pressure you are gunning for the larger your wastegate needs to be. An engine/turbo combination that is set to 25+psi has a smaller wastegate flow requirement than the same application set to 7 psi. This is because the wastegate is used to lower the boost not raise it, the lower the boost pressure is set the more flow the wastegate must allow. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tial website »</TD></TR><TR><TD CLASS="quote">
so basically the wastegate size is dependant on the variance of your boost levels your going to run? ex... massive turbo that you won't be utilizing much of it's potential at 7psi you'd need a larger wastegate, 40 or 44mm wastegate to bleed off all the excess boost. that same turbo at 30psi a 38mm should be sufficient?
back from the dead
back from the dead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT »</TD></TR><TR><TD CLASS="quote">
back from the dead
the theory makes sense....at 7psi you are bleeding off alot more exhaust gas then you would at 30psi, so a higher flowing wastegate would be needed to get it all out, without having problems controlling it and spiking.
sounds right at least
back from the dead
</TD></TR></TABLE>the theory makes sense....at 7psi you are bleeding off alot more exhaust gas then you would at 30psi, so a higher flowing wastegate would be needed to get it all out, without having problems controlling it and spiking.
this sounds like one of those " think outside the box " theories
what tial said does make sense to me
damn i wish i knew about this a long time ago , so i didnt have to sell my tial 35mm
I read this a while ago on the TiAL site but I drew my own conclusion....
The theory would still be true but the sizing I think also depends on the exhaust flow your motor puts out as well. Think about it... say a turbo gsr and a turbo 5.0 stang. the stang puts out more exhaust flow regardless. so say they're both running 18psi on the same size turbo (your avg t3/t04e). @ 18psi on the stang, it should be dumping more exhaust gas than the gsr. so for example. maybe the gsr could get away with a 38mm (based on TiAL's site), but the stang... being that it has more exhaust flow being dumped to hold the boost @ that level) would still probably need a larger valve size to accomodate.
Dunno if you guys get what I'm saying but bottom line is I think that the amount of exhaust gas the motor flows also plays a big part. Which is why built turbo honda guys that are pumping out more exhaust flow may run bigger w/g's than someone running lower boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost »</TD></TR><TR><TD CLASS="quote">InlinePro used a 35mm Turbosmart wastegate in their 9 second car
thanks for the info
</TD></TR></TABLE>thanks for the info
a1320honda
Feb 25, 2008 06:21 AM
