Anyone have tires that are 245 wide???
I also have 225s on 18s and they fit with a little room to spare (I have no inner liner though). I do believe that 245s on 17s will go... (the diameter of 225/40/18 is larger than a 245/40/17...25.1 vs 24.7inches)
you might be able to get away with it if you use a slightly different offset. Like I said before, the VW Golf MkIV's offset fit fine on my car (01 Golf GL 2.0). You could tell the tire was closer to the fender than the factory offset, but had no problem rubbing there or on the inside.
Yes, I have run those. They are a good all around tire. The tread wear is a little quick for me. But then I'm kinda hard on my tires. Just make sure you get them balanced regularly and you should be ok. They are getting expensive, so get em now.
eluder33
Apr 27, 2005 01:15 PM
, they rubbed a little bit... not much though... I only had them for like a week
