what other Si plugs are needed aside from, injector plugs for DPFI to MPFI???
ok before i waste my money on an si harness i just wanted to verify something here.
are there any other plugs from an Si harness that i need besides the four resistor plugs??
you pretty much need the four clips, alot of wire, and the injector resistor box. And check out hybrid-garage.com (under 4G tech) for a great write up on doing this.
I have si harness complete and uncut and a resistor box.I'll trade for the jdm hatch front bumper if you still have it.
sorry bumpe has been sold a while ago....
hey thanks for the info guys, i thought i needed an si distributor plug thats why i was asking...i already have a resistor box, 2 dx harnesses, and the si injector plugs.
i guess its time to start soldering...i'm going to extend every plug so i can mount the harness on the firewall...try to clean things up a bit i will def post some pics when done.
From: I told you to wait in the truck in Texas, United States
Easier to repin...the pins in the plug are super easy to get out.
I put the Si style plug on the engine harness so the SI distributor would just plug in;
I had an extra Si plug for the distrib,So I put it on the DX distributor before I
was ready to do the swap..That way,it was plug and play when I swapped in the B16.
Opps.. I already cut the harness and sodered everything back together before I read this email.. Strange, The wires on the dizzy don't like to hold soder for some reason even with flux on them.. Thanks for your help..
crex23
May 20, 2005 02:47 AM
