Need VAFC settings for a gsr
Old Oct 6, 2003 | 07:40 AM
OneFastGsr's Avatar
Default Need VAFC settings for a gsr
I need to know someones setting for a gsr with
4-1 header
aem cold air intake
Vafc
cat back exhaust
Or if u have slight mods please can u share ur setting numbers with me please
Old Oct 6, 2003 | 07:56 AM
patdemps's Avatar
Default Re: Need VAFC settings for a gsr (OneFastGsr)
Don't touch your VAFC!
the only place to mess around with a vafc is at the dyno with a qualified tuner. You never want to give your best guess settings, especially based on someone else's numbers. every car has different responses to mods, every car has a different amount of power, and every car needs a different setting. the advice im offering is to keep it stock until you hit a dyno, unless you don't care about your car and want to cause damage to it. you won't improve anything by guessing what your settings should be. your going to get the same answer from anyone that knows what they are talking about. so just find a dyno man . or keep your vafc settings stock
Old Oct 6, 2003 | 07:57 AM
BolivianDc2's Avatar
Default Re: Need VAFC settings for a gsr (patdemps)
I would say raise VTEC up to around 4800-5200, also might want to lean out the map a wee bit in the area in between the old VTEC point and the new point.
9INE_SIXGZR
Jan 26, 2007 08:13 AM
rohec04
Jul 2, 2005 01:45 PM
BoBo Racing
Mar 30, 2004 05:54 AM
SMOOTH97LUDE
Dec 26, 2002 08:01 PM
ITR 01-0840
Jan 7, 2002 04:59 PM
