is it true about the b17?
Old Oct 5, 2003 | 11:37 PM
mr. wu's Avatar
Default is it true about the b17?
i was reading and saw something about honda making 2 different versions of the b17. the difference was that one had a higher deck hight than the other, so there for it also had different sized rods. in the b17 with the higher deck hight it had the same size rods as the b18a, b18b. the reason i want to know is because i am putting a b17 crank in my b16 and i want to make sure that i get the right rods. i don't want to buy b17 rods that are going to be too long, or or to short. if any one could help me out with any sort of information about this that would be great.
Old Oct 5, 2003 | 11:53 PM
ill phil's Avatar
Default Re: is it true about the b17? (mr. wu)
As far as I know- b16a/b17 block= same thing deck height wise. Only difference is the internals.
Old Oct 5, 2003 | 11:58 PM
mr. wu's Avatar
Default Re: is it true about the b17? (ill phil)
that is what i thought too, but as of today i am not sure. any one else know anthing about this?
Old Oct 6, 2003 | 01:12 AM
TimoneX's Avatar
New User
Don't think so. Someone probably confused a B17 GSR motor and a B18a. B17 rods are 5.208"(132.3mm) with 1.890" big end bores. Get rods fitting that description and they'll work fine in a B16/17 block w/ a B17 crank.
lunatics209
Jun 12, 2008 01:38 AM
weiRtech
Aug 24, 2006 11:00 AM
BigPlansNoMoney
Nov 18, 2004 11:14 AM
mr. wu
Oct 7, 2003 10:00 AM
88CRXHybrid
Apr 28, 2002 07:12 PM
