still burning oil
Old Oct 5, 2003 | 09:17 PM
notsure's Avatar
Default still burning oil
so i have been burning oil for awhile, at first i thought it was the rings. got new piston installed, after break in I was still burning. so i was like oh, its the valve seals. had those replaced, still burning oil. i pulled the plugs and there was oil on the threads. so i cleaned it off, and started the motor, pulled them again and there was still oil in the same place. wtf btw, ls/vtec lots of mods
Old Oct 5, 2003 | 10:48 PM
Malgerus's Avatar
Default Re: still burning oil (notsure)
Have you done a leakdown test?
Old Oct 6, 2003 | 05:28 AM
jeremy.'s Avatar
Default Re: still burning oil (Mr. S)
bump
Old Oct 6, 2003 | 08:47 AM
notsure's Avatar
no i havent, is that something that i can do or is it something that has to be done at a shop
Old Oct 6, 2003 | 09:01 AM
advanracing62's Avatar
depends on your compentency as a mechanic, it's pretty easy to do a leak down test... but I know people who have screwed something up doing it...
Old Oct 7, 2003 | 12:22 AM
aeolus's Avatar
Default Re: still burning oil (advanracing62)
if theres oil on the threads,you have a valve cover gasket leak.Those O-ring seals.How does the insulator look by the points?
Old Oct 10, 2003 | 12:08 PM
Mach30SiR's Avatar
Default Re: still burning oil (aeolus)
bump....you should have heard this bad boy missfiring the other day.
serjey15
Dec 4, 2010 07:20 PM
Hill4589
Apr 10, 2009 04:56 PM
Jeff
Apr 18, 2005 06:23 AM
98cwitr
Apr 27, 2004 01:34 PM
Accel Junky
Apr 28, 2003 02:18 PM
